Low oil pressure problem #772943
08/13/10 04:10 PM
08/13/10 04:10 PM
united kingdom
blown360 Offline OP
blown360  Offline OP
united kingdom
Were having problems with my buddies 500 indy motor. Since we installed Harland rockers we seem to have lost some oil pressure. When its hot its only making 40-50 @ 6800 rpm. Ive modified the oil feed pipes to te indy heads and fitted size 60 NOS jets but dont know how much restriction I can run to these rockers. Its got a high vol oil pump fitted and I just cant figure out where were losing the pressure! Its a fairly fresh motor and we always had good pressure until we switched to the harlands. Any ideas people?
Re: Low oil pressure problem [Re: blown360] #772944
08/13/10 07:29 PM
08/13/10 07:29 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
You must be getting a TON of oil up in heads and valve gear ... have you tried viewing this as the engine is running ?
Re: Low oil pressure problem [Re: blown360] #772945
08/13/10 09:05 PM
08/13/10 09:05 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Sounds like maybe there is too much clearance between the rockers..
Were these shimmed properly, and then rechecked after torqueing down the shaft..
Just my $0.00..
Re: Low oil pressure problem [Re: blown360] #772946
08/14/10 01:35 AM
08/14/10 01:35 AM
Your having the typical over oiling problem when using true roller rockers like Harland Sharps, T&D and so on, not bushed rockers,on a single shaft. Try restricting it down some more, are you using two restrictor jets, one in each head or one in the T block going to both heads? One is probally better than two
Re: Low oil pressure problem [Re: Cab_Burge] #772947
08/14/10 11:26 AM
08/14/10 11:26 AM
united kingdom
blown360 Offline OP
blown360  Offline OP
united kingdom
I didnt fit them my buddy did so not sure if they need shimming? Tbh I wasnt aware they'd need to be shimmed I thought they would be just bolt on and go! I fitted two NOS jets one in each pipe as we had to try find a solution quickly! Pressure did increase but not as much as we need! isnt the golden rule 10psi per 1000rpm? Do I need to shim these rockers or just downsize the NOS jets more?
Re: Low oil pressure problem [Re: blown360] #772948
08/14/10 02:10 PM
08/14/10 02:10 PM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
Bump
I would like to know the best way on this subject too. Oil restriction that is.
Re: Low oil pressure problem [Re: Bigbeep] #772949
08/14/10 03:35 PM
08/14/10 03:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have a problem with restricting the oil that much
to each head when using a single shaft... it takes so
long for the oil to fill the tube and finally make
it to the push rod cup/tip which could cause a push
rod tip issue... I would rather have some pressure in
the shaft and restrict the side play and maybe even
use a simple seal on each side of the rocker to hold
more in there.... would be a whole nother game if you
were push rod oiling.... then I could see a .015
orifice in each push rod... I have .030 in each push
rod and thats more than plenty... JMO
Re: Low oil pressure problem [Re: MR_P_BODY] #772950
08/14/10 03:41 PM
08/14/10 03:41 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
NOT ONLY a push rod issue .... you could also TOAST valve springs.
MOST of the cooling that VSs get is from oil. But then again ....tooo much oil up-there costs HP to drive the pump THEN there is the HP loss with the crank and rods driving-through all that excess drain-back oil.
Re: Low oil pressure problem [Re: dOoC] #772951
08/14/10 07:40 PM
08/14/10 07:40 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I just put on a set of HS also I was just in the garage priming the oil I have a .069 jet in each line and that is still WAY to much oil up top and I have the side clearence set at .012 so I will have to change jets
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Low oil pressure problem [Re: dusturbd340W5] #772952
08/15/10 07:25 AM
08/15/10 07:25 AM
united kingdom
blown360 Offline OP
blown360  Offline OP
united kingdom
Cheers everyone I think Ill try going a little lower on the jet sizes to see if we can get the pressure back up and maybe see if I can shim them out a bit to add restriction. Can you get a shim kit for these rockers or will I just have to find some that fit? I wont get to be with the car for a couple more weeks til we get back to the track so I'll just have to wait and see how it goes I guess. I really dont wanna toast his top end so I'll just have to keep an eye on things as we go!
