Gforce 101A or Jerico for my 70 Challenger? #772883
08/13/10 12:34 PM
08/13/10 12:34 PM
Massachusetts
E
ericlre79 Offline OP
E
Massachusetts
Ok Mopar guys, the A833 with liberty treated proshifted, etc, will not do...I want to bang the gears fast...Here the sticky part.....its an original 70 RT/SE 383 stick car....former stocker, going to be again, but I don't want to cut much if any on the floor.....# matching block and tranny safely tucked away.
Anyone have an idea on which tranny requires less alteration?
Eric Merryfield
Stk, SS 1883
Re: Gforce 101A or Jerico for my 70 Challenger? [Re: ericlre79] #772884
08/13/10 01:23 PM
08/13/10 01:23 PM
ohio
mike67net Offline
mopar addict
mike67net  Offline
mopar addict
ohio
I know a guy that was able to put a Jerico in his B-body without cutting the car up. The tranny fits but normally you'll do some cutting to get the V-gate shifter in. He was able to fabricate a mount and install a Hurst shifter in his.
I cut my car but I saved the pieces and I can put it back to original if I ever decide to.
Oh, and you'll need to modify the crossmember so you could buy one and save the original.
Re: Gforce 101A or Jerico for my 70 Challenger? [Re: ericlre79] #772885
08/13/10 08:35 PM
08/13/10 08:35 PM
Chicago, IL
blownEFI Offline
blownEFI  Offline
Chicago, IL
How much power?
You could try a Keisler 5-speed based on the Tremec TKO-600 which should fit without any modifications. Plus you get an overdrive gear for highway cruising.
"These go to eleven", Nigel Tufnel
Re: Gforce 101A or Jerico for my 70 Challenger? [Re: blownEFI] #772886
08/16/10 01:28 PM
08/16/10 01:28 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Interesting post as I plan on doing this to my Challenger also. G-Force, Jerico or Liberty? Haven't decided yet on which one for sure.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
