Re: Welding in trunk floor on ebody???
[Re: cudabitten]
#772675
08/13/10 04:24 AM
08/13/10 04:24 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Can't you screw it down and then weld up the screw holes as you go along?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: cudabitten]
#772677
08/14/10 02:07 PM
08/14/10 02:07 PM
Posts: 199 douglasville,ga
ramrod
douglasville,ga
I just put a trunk floor in a '70 Challenger, and I REFUSED to drill the frame rails! I used the existing holes in the pan for access to clamp things up where I could, and the following idea: take an 8 foot long 2x4, turn it narrow edge up and wedge it under the cross brace at the top- in the corner at the inner wheel house. Wedge a short 2x4 under the long one to act as a fulcrum in the spots where you need to force the pan down on the rails. Have a helper pull down on the end of the long 2x4, or if you are working alone like me- hang some weight from the end. I hope you can picture it from my description.... sorta like a see-saw with a moveable fulcrum.
"That Plymouth had a Hemi with a Torqueflite."
-Driver
