Re: Magnum Block RWHP limit?
[Re: rtspeeddemon]
#772243
08/12/10 10:21 PM
08/12/10 10:21 PM
Posts: 2,489 Pacifica, CA
Devilbrad
Pacifica, CA
I think you've exceeded the limit, LOL I don't know of any other Mag motors making that much at the tires. Have a friend with a turbo 360 in a Gen 2 making around 600hp, he wont give exact numbers though. Come on over to my message board: www.racemagnum.com/index.php you will find more Magnum truck owners making power. Warning: we have no rules there, but we like technical stuff.
[Re: Devilbrad]
#772244
08/12/10 11:15 PM
08/12/10 11:15 PM
Posts: 1,969 Chandler, AZ
Duner
Chandler, AZ
Yer all just a buncha trouble makers over there.
[Re: Duner]
#772245
08/12/10 11:18 PM
08/12/10 11:18 PM
Devilbrad
Pacifica, CA
We are the kids from the bad neighborhood!
[Re: Devilbrad]
#772247
08/13/10 09:30 AM
08/13/10 09:30 AM
Posts: 41 Ontario, Canada
rtspeeddemon
Ontario, Canada
Well looks like we are going to stretch the envelop a bit farther sometime this fall as my garage says we are taking a shot at a 9.9X pass. Basically if all the conditions are right, temp, humidity, track prep etc and truck is running lets say 10.2-10.3 then we will turn the screw and add a touch more boost and take a shot at the 9 sec number. They really think the truck can hit it so guess we are going to find out or need the broom to sweep off the track.
[Re: TheOtherDodge]
#772249
08/13/10 10:27 AM
08/13/10 10:27 AM
rtspeeddemon
Ontario, Canada
What have you done to the block? Mine is partial filled, 2 bolt billet caps, main and head studs.
1/3 partial fill, and a Hughes main girdle. Caps are stock, ARP main and head studs and running an SCE copper head gasket with o-ringed heads.
[Re: TheOtherDodge]
#772250
08/13/10 10:28 AM
08/13/10 10:28 AM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Turbos are fairly easy on the engine. It's nitrous and rpm that are the two big engine killers.
[Re: rtspeeddemon]
#772251
08/13/10 04:02 PM
08/13/10 04:02 PM
Posts: 142 Maryland
Sick 660r
Maryland
712 here but I only have maybe 10 passes. I've been doing alot of daily driving with it the past month. I also have the LA main webbing and a short fill along with billet caps.
2000 dakota
418 magnum
paxton novi 2k
T56
[Re: Sick 660r]
#772252
08/13/10 08:36 PM
08/13/10 08:36 PM
rtspeeddemon
Ontario, Canada
We figure we need about 800 rwhp to hit a 9.9X pass which is easy for me to obtain with about 3 more lbs boost but man that is pushing things.
[Re: rtspeeddemon]
#772253
08/13/10 08:53 PM
08/13/10 08:53 PM
Posts: 142 Maryland
Sick 660r
Maryland
Also consider my paxton is using up some of the power but I have a manual.
What stories have you heard of blocks failing? I know you had an issue but you also said many things could have caused it. Slammed's block is still good even after melting a piston and he as tons of passes. Most people dont push a magnum block this far so I dont think we know its true limit. IMO the 500rwhp limit theory has been busted.
2000 dakota
418 magnum
paxton novi 2k
T56
[Re: rtspeeddemon]
#772256
08/15/10 05:14 PM
08/15/10 05:14 PM
Posts: 142 Maryland
Sick 660r
Maryland
I dont think many have. I know chad is going for 8's with a magnum 408, 46RE, and a 400 shot.
2000 dakota
418 magnum
paxton novi 2k
T56
[Re: rtspeeddemon]
#772257
08/15/10 07:02 PM
08/15/10 07:02 PM
Posts: 377 Michigan Troll
blk00rt
Michigan Troll
kj, you going to bring that beast down to woodward next weekend?
Rob Dunn 1976 Dart Sport 360 2000 dakota RT 408 with 150 nitrous 2013 Dodge Ram 1500 Hemi 2009 Jeep Patriot
[Re: blk00rt]
#772258
08/15/10 07:10 PM
08/15/10 07:10 PM
Posts: 142 Maryland
Sick 660r
Maryland
KJ, what internals do you have?
2000 dakota
418 magnum
paxton novi 2k
T56
