SB roller cam ID help #772134
08/12/10 12:46 PM
08/12/10 12:46 PM
Billings, Mt.
K
KLH Offline OP
KLH  Offline OP
K
Billings, Mt.
Picked up a 340 with roller, was told it had a comp roller but can't seem to ID properly.
Has stamped on end 2018 B.
Scribed on end 1476S/1476S, SB106, X4588.
Has some white paint between last lobe and distributor drive gear.
Has anyone seen markings like this?
Ken
Re: SB roller cam ID help [Re: KLH] #772135
08/12/10 01:37 PM
08/12/10 01:37 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
My entry
HE Street roller
288
244 at .050
550 lift w/1.5
106 LC
Re: SB roller cam ID help [Re: RobX4406] #772136
08/12/10 06:45 PM
08/12/10 06:45 PM
Billings, Mt.
K
KLH Offline OP
KLH  Offline OP
K
Billings, Mt.
RobX4406, thanks for the post.
I take by HE you mean Herbert?
What portions of the markings lead you to that conclusion and where can I find the specs you listed?
I'm after the clearances, etc.
Ken
Re: SB roller cam ID help [Re: KLH] #772137
08/12/10 06:47 PM
08/12/10 06:47 PM
Billings, Mt.
K
KLH Offline OP
KLH  Offline OP
K
Billings, Mt.
Here's a pic of a set of rollers.
Might help with the ID.
Ken
Re: SB roller cam ID help [Re: KLH] #772138
08/12/10 07:23 PM
08/12/10 07:23 PM
RobX4406 Offline
RobX4406  Offline
HE = High Energy
Comp cam line.
Re: SB roller cam ID help [Re: RobX4406] #772139
08/12/10 07:50 PM
08/12/10 07:50 PM
Billings, Mt.
K
KLH Offline OP
KLH  Offline OP
K
Billings, Mt.
I forgot to add it's a solid roller, not hydraulic.
Re: SB roller cam ID help [Re: RobX4406] #772140
08/12/10 08:32 PM
08/12/10 08:32 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
My entry
HE Street roller
288
244 at .050
550 lift w/1.5
106 LC
I found the 1476 lobe in the High Energy Street Roller section of my CC catalog. Valve lash is .020".
Floyd Lippencott IV
Re: SB roller cam ID help [Re: mr_340] #772141
08/12/10 09:32 PM
08/12/10 09:32 PM
Billings, Mt.
K
KLH Offline OP
KLH  Offline OP
K
Billings, Mt.
Thanks guys.
Appreciate it.
