Max safe CR for Fel-Pro 8519 PT-1 bb head gasket? #771404
08/11/10 01:02 PM
08/11/10 01:02 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
I'm planning to use the "standard" Fel-Pro 8519 PT-1 composition head gasket w/ my Victor heads and targeting around 10.8 CR. Is this CR w/in the acceptable safe range for this particular head gasket?
Re: Max safe CR for Fel-Pro 8519 PT-1 bb head gasket? [Re: BradH] #771405
08/11/10 01:21 PM
08/11/10 01:21 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
They will probably work, but I would use the 1000 series gaskets with aluminum heads. They are what Edelbrock recommends and I use them on my small block. Trouble free after 40,000 miles.
Re: Max safe CR for Fel-Pro 8519 PT-1 bb head gasket? [Re: BradH] #771406
08/11/10 01:46 PM
08/11/10 01:46 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Brad that is the head gasket that dewayne told me to use with my 11.1 440 with indy EZ heads.Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Max safe CR for Fel-Pro 8519 PT-1 bb head gasket? [Re: BradH] #771407
08/11/10 01:49 PM
08/11/10 01:49 PM
an8sec70cuda Offline
They'll work fine.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Max safe CR for Fel-Pro 8519 PT-1 bb head gasket? [Re: an8sec70cuda] #771408
08/11/10 03:13 PM
08/11/10 03:13 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Years and years of abuse on a 12:1 493 with Indy heads. I reuse them also. II just dont or know anyone who has trouble sealing these big Mopar engines..
Re: Max safe CR for Fel-Pro 8519 PT-1 bb head gasket? [Re: Bob_Coomer] #771409
08/12/10 02:27 AM
08/12/10 02:27 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
Same here, several pump gas 11-12:1 engines we have used those gaskets in. Never had problems, the best one made 781 hp.
Plynouth VIP '67 TT IC EFI
Re: Max safe CR for Fel-Pro 8519 PT-1 bb head gasket? [Re: BradH] #771410
08/12/10 04:28 AM
08/12/10 04:28 AM
Brad, after blowing the Fel Pro 1009 out on the dyno my 527 bracket motor with 12.8 to 1 compression using 108 octane race gas I decided to change the head gaskest out on my 518 pump gas motor when I put the 440-1 heads on it. I had 1009 on the 518 and they look fine after a lot of reuse and abuse, they where squished out into the cylinders a tiny bit so I decided while it was apart to change them. I had sets of Cometics, Mr Gasket MLS, Fel Pro 8517PT, Fel Pro 1009 (Fel Pro 8519PT EDIT)and several sets of SCE Copper gaskets in stock that would haave work on the motor I selected the 8519PT (edited the proper part number) The set I measured has a 4.480 bore across the wrist pin area in the center of the bore, I lost a little bit of compression versus using the 1009 but I didn't want to take a chance of having the 1009 blow out again, regardless of the reasons the 527 and the 518 have bores of 4.375(low deck 518 motor) and 4.380 in the 440 block 527 C.I. motor
Re: Max safe CR for Fel-Pro 8519 PT-1 bb head gasket? [Re: Cab_Burge] #771411
08/12/10 07:48 AM
08/12/10 07:48 AM
mogadore ohio 44260
racingblues1426 Offline
mogadore ohio 44260
What is the compressed thickness of the 8517pt gasket and who makes it? Thanks
Re: Max safe CR for Fel-Pro 8519 PT-1 bb head gasket? [Re: racingblues1426] #771412
08/12/10 08:02 AM
08/12/10 08:02 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
At 10.8 I'm sure you will be fine. At 14 to 1 they blow out the front of the car on fire and burn on the track for a few minutes...That much I know
Re: Max safe CR for Fel-Pro 8519 PT-1 bb head gasket? [Re: racingblues1426] #771413
08/12/10 12:28 PM
08/12/10 12:28 PM
BradH Offline OP
BradH  Offline OP
Assuming that Jyrki made a typo and he really meant the 8519PT, it's a standard Fel-Pro BBM gasket that's approx. .040" thick and has an advertised volume of 10.9 cc, IIRC.
My reason for considering this gasket is the increased diameter of the fire ring compared to something like an FP 1009 or DG/Corteco race gasket. A 1009 won't work on my 452's 4.380" bore and I have to elongate the dowel pin slots slightly to offset the DG gasket enough to not overhang the chambers on my Stage VIs.
Re: Max safe CR for Fel-Pro 8519 PT-1 bb head gasket? [Re: BradH] #771414
08/12/10 12:32 PM
08/12/10 12:32 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`m running the marine gasket by fel-pro going on 5 1/2 years..........plenty of clearance around the bore and the stainless fire ring.
Re: Max safe CR for Fel-Pro 8519 PT-1 bb head gasket? [Re: Thumperdart] #771415
08/12/10 12:34 PM
08/12/10 12:34 PM
BradH Offline OP
BradH  Offline OP
Have you pulled the heads off since they were installed w/ the marine-spec gasket to see if they have been brinelled by the fire ring?
Re: Max safe CR for Fel-Pro 8519 PT-1 bb head gasket? [Re: BradH] #771416
08/12/10 12:43 PM
08/12/10 12:43 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
No I havn`t...........if it aint broke don`t fix it and I`m not one to tear into my motor just to check things out. It hasn`t been apart since I built it except for a valve spring swap.
Re: Max safe CR for Fel-Pro 8519 PT-1 bb head gasket? [Re: Thumperdart] #771417
08/12/10 04:38 PM
08/12/10 04:38 PM
NC
440Jim Offline
440Jim  Offline
NC
There is something to be said for that. How many passes in those 5-1/2 years?
For a race engine, I would consider a tear down this winter if you have a bunch of passes on it. Sometimes preventive maintenance is better than a broken crank, rods, pistons, block, etc. A set of bearings and gaskets is good insurance.
Re: Max safe CR for Fel-Pro 8519 PT-1 bb head gasket? [Re: 440Jim] #771418
08/12/10 05:00 PM
08/12/10 05:00 PM
Airdrie, AB
Mills Offline
Mills  Offline
Airdrie, AB
They held up fine with my 11.1:1. Went with them for the very same reason you state - 60 over 440 wouldn't allow the other gasket to work.
1967 Satellite, CNC Eddy Headed 500ci Street Mauler
(Dyno'ed @ 600 HP / 650 ft-lbs)
2016 Challenger Hellcat - Holy Hell
2012 Hemi Ram Sport Crew Cab
2011 Avenger, Pentastar V-6
2007 SRT-8 Charger (Dyno'ed @ 470 RWHP)
1986 Caravelle, 318, aka "Rosco", Back Road Burner!
ALL Black...Bad Boys always wear Black!
Re: Max safe CR for Fel-Pro 8519 PT-1 bb head gasket? [Re: Mills] #771419
08/13/10 01:33 AM
08/13/10 01:33 AM
I misstated the part number I used on my 518, tey are the 8519PT, not the 8517PT I have edites the first post, I hope this didn't affect anyone
Re: Max safe CR for Fel-Pro 8519 PT-1 bb head gasket? [Re: 440Jim] #771420
08/13/10 01:45 AM
08/13/10 01:45 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Good points Jim I agree 100%
I actually have found my self excited to see how everything looks in a new engine after 1 season of hard runs...
The weather here is pretty crappy during the winters, cant do much, its easy to get the race car blue's, and loose some enthusiasm, or just plain old case of loss of interest. Thats why I like to work on the project over the winter, make changes, check things out...basically spend some money LOL
Back to the PT gaskets
They have a very large bore 4.52-4.53 I recommend these to the Stealth head guys cause of the large bore, they address the chamber issue shortcomings they use to have. They are near .040 thick...maybe .038-.040
No way these are only 10 cc compressed more like 13.5-14 but I would need to do some math to be positive.
Re: Max safe CR for Fel-Pro 8519 PT-1 bb head gasket? [Re: scatpacktom] #771421
08/13/10 02:22 AM
08/13/10 02:22 AM
Texas
6packattk Offline
6packattk  Offline
Texas
I just laughed to tears on picture of that comment insighted and have only one question,what was plan b.I have had 12-1 in 3604x4 truck and found out the hard way in 80`s with vortex booster and premium gas mix hammered out bearings.Had fel pro composition gaskets in that.Curious on what gasket did work for that much squish.
Re: Max safe CR for Fel-Pro 8519 PT-1 bb head gasket? [Re: BradH] #771422
08/13/10 04:56 AM
08/13/10 04:56 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Worked fine on the old 451 with B1-B/S heads.
This is from a post I made about gaskets for the stealth heads:
If you get the Fel-Pro KS2110 gasket kit ($55 for a full gasket set from Summit Racing - minus valley tray) the 8519PT1 head gasket will fit the stealth heads. The 8519PT1 measures 4.5" bore diameter and is 0.040" thick, or about 10.4cc (calculated.)
Re: Max safe CR for Fel-Pro 8519 PT-1 bb head gasket? [Re: 440Jim] #771423
08/13/10 02:06 PM
08/13/10 02:06 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Don`t totally keep track but probably 300+ and it`s a street car that I race once in a while. I do want to freshen it up this year and port the heads a bit more and let er rip unless I find issues. Good advice...............
