Re: Max safe CR for Fel-Pro 8519 PT-1 bb head gasket?
[Re: BradH]
#771407
08/11/10 01:49 PM
08/11/10 01:49 PM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
[Re: an8sec70cuda]
#771408
08/11/10 03:13 PM
08/11/10 03:13 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Years and years of abuse on a 12:1 493 with Indy heads. I reuse them also. II just dont or know anyone who has trouble sealing these big Mopar engines..
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#771409
08/12/10 02:27 AM
08/12/10 02:27 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
Same here, several pump gas 11-12:1 engines we have used those gaskets in. Never had problems, the best one made 781 hp.
Plynouth VIP '67 TT IC EFI
[Re: BradH]
#771410
08/12/10 04:28 AM
08/12/10 04:28 AM
Posts: 43,228 Bend,OR USA
Cab_Burge
Brad, after blowing the Fel Pro 1009 out on the dyno my 527 bracket motor with 12.8 to 1 compression using 108 octane race gas I decided to change the head gaskest out on my 518 pump gas motor when I put the 440-1 heads on it. I had 1009 on the 518 and they look fine after a lot of reuse and abuse, they where squished out into the cylinders a tiny bit so I decided while it was apart to change them. I had sets of Cometics, Mr Gasket MLS, Fel Pro 8517PT, Fel Pro 1009 (Fel Pro 8519PT EDIT)and several sets of SCE Copper gaskets in stock that would haave work on the motor I selected the 8519PT (edited the proper part number) The set I measured has a 4.480 bore across the wrist pin area in the center of the bore, I lost a little bit of compression versus using the 1009 but I didn't want to take a chance of having the 1009 blow out again, regardless of the reasons the 527 and the 518 have bores of 4.375(low deck 518 motor) and 4.380 in the 440 block 527 C.I. motor
[Re: racingblues1426]
#771413
08/12/10 12:28 PM
08/12/10 12:28 PM
BradH
What is the compressed thickness of the 8517pt gasket and who makes it? Thanks
Assuming that Jyrki made a typo and he really meant the 8519PT, it's a standard Fel-Pro BBM gasket that's approx. .040" thick and has an advertised volume of 10.9 cc, IIRC.
My reason for considering this gasket is the increased diameter of the fire ring compared to something like an FP 1009 or DG/Corteco race gasket. A 1009 won't work on my 452's 4.380" bore and I have to elongate the dowel pin slots slightly to offset the DG gasket enough to not overhang the chambers on my Stage VIs.
[Re: BradH]
#771414
08/12/10 12:32 PM
08/12/10 12:32 PM
Thumperdart
State of confusion
I`m running the marine gasket by fel-pro going on 5 1/2 years..........plenty of clearance around the bore and the stainless fire ring.
[Re: BradH]
#771416
08/12/10 12:43 PM
08/12/10 12:43 PM
Thumperdart
State of confusion
No I havn`t...........if it aint broke don`t fix it and I`m not one to tear into my motor just to check things out. It hasn`t been apart since I built it except for a valve spring swap.
[Re: Thumperdart]
#771417
08/12/10 04:38 PM
08/12/10 04:38 PM
Posts: 16,928 NC
440Jim
NC
There is something to be said for that. How many passes in those 5-1/2 years?
For a race engine, I would consider a tear down this winter if you have a bunch of passes on it. Sometimes preventive maintenance is better than a broken crank, rods, pistons, block, etc. A set of bearings and gaskets is good insurance.
[Re: 440Jim]
#771418
08/12/10 05:00 PM
08/12/10 05:00 PM
Posts: 1,379 Airdrie, AB
Mills
Airdrie, AB
They held up fine with my 11.1:1. Went with them for the very same reason you state - 60 over 440 wouldn't allow the other gasket to work.
1967 Satellite, CNC Eddy Headed 500ci Street Mauler (Dyno'ed @ 600 HP / 650 ft-lbs)
2016 Challenger Hellcat - Holy Hell 2012 Hemi Ram Sport Crew Cab 2011 Avenger, Pentastar V-6 2007 SRT-8 Charger (Dyno'ed @ 470 RWHP) 1986 Caravelle, 318, aka "Rosco", Back Road Burner!
ALL Black...Bad Boys always wear Black!
[Re: 440Jim]
#771420
08/13/10 01:45 AM
08/13/10 01:45 AM
Bob_Coomer
Rock Springs
Good points Jim I agree 100% I actually have found my self excited to see how everything looks in a new engine after 1 season of hard runs... The weather here is pretty crappy during the winters, cant do much, its easy to get the race car blue's, and loose some enthusiasm, or just plain old case of loss of interest. Thats why I like to work on the project over the winter, make changes, check things out...basically spend some money LOL
Back to the PT gaskets They have a very large bore 4.52-4.53 I recommend these to the Stealth head guys cause of the large bore, they address the chamber issue shortcomings they use to have. They are near .040 thick...maybe .038-.040 No way these are only 10 cc compressed more like 13.5-14 but I would need to do some math to be positive.
