Page 4 of 4 1 2 3 4
Re: Ray Barton 528 failure what to look for, what happe [Re: gdonovan] #771325
08/31/10 05:09 PM
08/31/10 05:09 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
If that engine was turning 7,000 RPMs with only 5 quarts of oil in the pan, there's little doubt you exposed the oil pick-up and were sucking air.
That was my thought.
No doubt in my mind, that's what spun the main bearings. How can you have spun bearings yet no signs of oil starvation?
7 flat cam lobes?? The valve train was not setup right from the get go either and is not supposed to be loud. Audible yea, loud no.
Re: Ray Barton 528 failure what to look for, what happe [Re: Challenger 1] #771326
08/31/10 06:36 PM
08/31/10 06:36 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
i dont think pan/pickup/oil level had anything to do with what happen, you would have to hold pedal down @7,500 rpms for over 2 minute to cavitate stock oil pan, hemi heads/block have huge return holes on all four coners,wedge dont. think cam fried and packed all bearings feeds with oil shut off oil flow to them, if it keep runing would be rods out the block...
MOPAR OR NO CAR
Re: Ray Barton 528 failure what to look for, what happe [Re: hemigod426] #771327
08/31/10 07:07 PM
08/31/10 07:07 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Perhaps I'm wrong, did not Hemi's come with a 6 quart pan from the factory?
Re: Ray Barton 528 failure what to look for, what happe [Re: imfixinmopars426] #771328
08/31/10 09:54 PM
08/31/10 09:54 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
since cam failed,wonder if it was broken in w/ light springs? then inners added after? or just slammed together,and shipped? hmmmmm
I wonder if it was the chicken first then the egg or vice versa (did the cam fail and cause the other damage or did the bearing fail and cause the damage) I think the cam failed and took everything else with it.
Re: Ray Barton 528 failure what to look for, what happe [Re: Challenger 1] #771329
08/31/10 10:22 PM
08/31/10 10:22 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
Challenger1, I have the same engine. There's a YouTube link in my sig. to my engine on the dyno. Give a listen. I honestly don't know if it should be that loud.
Re: Ray Barton 528 failure what to look for, what happe [Re: Vert] #771330
09/14/10 10:52 PM
09/14/10 10:52 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
ChrisDavis,
Any news on your engine?
Re: Ray Barton 528 Valve Train Oiling [Re: 64Post] #771331
09/29/10 05:37 PM
09/29/10 05:37 PM
Illinois
ChrisDavis Offline OP
Illinois
Are any of you familiar with how Ray Barton oils the valve train?
In tearing the engine down I see sprayers on the intake rockers, but not on the exhausts. Also the lifter boars are bushed and the bushings have no oil holes at all in them. Ray Barton’s people are telling me that the cam splashes enough to keep the solid lifters oiled and that the intake sprayers will splatter around enough for the exhausts.
My engine rebuilder disagrees and is going to drill an oil hole in the lifter bushings and possibly the exhaust rocker shafts as well. What do you think about Ray Barton’s oiling and what my engine rebuilder wants to do?
Re: Ray Barton 528 Valve Train Oiling [Re: ChrisDavis] #771332
09/29/10 09:35 PM
09/29/10 09:35 PM
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
The holes in the bushing are done for hydraulic cams or engines that oil the valve gear with lifters/pushrods designed for through the push rod oiling ah-la Chevrolet. They are correct in that a solid lifter/solid roller would get enough oil from splash and won't need the holes.
The spray nozzle thing is interesting. Normally it's the exhaust push rods that get the spray nozzles
Re: Ray Barton 528 Valve Train Oiling [Re: ChrisDavis] #771333
09/29/10 09:39 PM
09/29/10 09:39 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Chris,
Contact Mike Chenowith at CRE, 309-266-8084. They are in Morton, Ill.
Re: Ray Barton 528 failure what to look for, what happe [Re: torkrules] #771334
09/29/10 11:53 PM
09/29/10 11:53 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
The idle slowed because the cam failed, pick-up is blocked because the screen is full of camshaft, starved pump, boom.
Kevin
Re: Ray Barton 528 failure what to look for, what happe [Re: 64Post] #771335
10/18/10 02:33 PM
10/18/10 02:33 PM
Illinois
Illinois
I thought some of you might want to see a picture. Here is a photo of one rod, main and cam bearing. All the other bearings look about the same as these. The cam bearings were in the worst shape and had worn almost all the way through the bearing. Although the cam shaft doesn’t look anywhere near as nasty as its bearings do. The rod bearings where in the best shape and although they had lost their surface there weren’t all torn up like the mains.
The engine is back together and we will be putting it back in the car in a week or so. Oiling improvements have been made so I hope to not see this again.
Re: Ray Barton 528 failure what to look for, what happe [Re: ChrisDavis] #771336
10/18/10 02:35 PM
10/18/10 02:35 PM
Cincinnati, Ohio
Cincinnati, Ohio
Good luck with it!!
Re: Ray Barton 528 failure what to look for, what happe [Re: Twostick] #771337
10/18/10 04:12 PM
10/18/10 04:12 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Kevin
the pickup wouldn't be clogged with camshaft unless the particles were very big , metal on metal grinding leaves very small pieces , what happens is they get thru the screen and into the oil pump and it does a number on the oil pump since the oil goes thru it before it gets filtered.
Good luck with the second bullet , did you go back to Barton with it or take it elsewhere ?
Re: Ray Barton 528 failure what to look for, what happe [Re: JohnRR] #771338
10/18/10 05:15 PM
10/18/10 05:15 PM
Illinois
Illinois
I took it to Pfeiffer's Racing Engines in Freeport, IL. All Ray Barton would tell me was send it back and they would tell me what happened. I think I ended up with a much more meticulous rebuild with Steve Pfeiffer. He has a strong reputation around these parts. The bill was somewhat staggering, but a large part of that was a custom ground roller cam, Crower lifters, valve springs and push rods.
Re: Ray Barton 528 failure what to look for, what happe [Re: ChrisDavis] #771339
10/18/10 06:24 PM
10/18/10 06:24 PM
Sonora, CA
68X426 Offline
68X426  Offline
Sonora, CA
Chris: did you finally drill oil holes in the rocker shafts and/or the rocker arms?
The 12 Scariest Words in the English Language: We are here from the Government and we want to help you. 1968 Plymouth Road Runner, Hemi and much more 1968 Dodge Charger, 318 and not much else 1958 Dodge Pick Up, 383 and loud 1966 Dodge Van, Slant 6 and cool
Re: Ray Barton 528 failure what to look for, what happe [Re: 68X426] #771340
10/18/10 06:54 PM
10/18/10 06:54 PM
Illinois
Illinois
They were going to drill holes in the exhaust rocker shafts, but discovered they were oiling fine when the engine was primed. Don't forget these are Ray Barton rockers and there are multiple short shafts. They did drill holes in the lifter boar sleeves. I guess Ray Barton figured that cam splash was enough lubrication for the lifters. Steve Pfeiffer disagreed.
Page 4 of 4 1 2 3 4
