Help with small bolts-"67 GTX Body assembly,please #770912
08/10/10 08:49 PM
08/10/10 08:49 PM
Canfield,Ohio,USA
gassy66 Offline OP
gassy66  Offline OP
Canfield,Ohio,USA
While cleaning bolts/clips prior to painting prior to assembling finally now painted Body parts,I noticed two small bolts 1/4"x 1"long,with
large copper washers with Lead coating on other
side? They go into assembling front metal parts
and braces,but I'm not sure where they came from
exactly,and they were covered with paint
and undercoating at dissassembly,so went unnoticed
-I'm guessing the intent is to provide a good
electrical ground,possible fastening the brace between K-member and core support?? Anybody??
Re: Help with small bolts-"67 GTX Body assembly,please [Re: gassy66] #770913
08/10/10 08:58 PM
08/10/10 08:58 PM
Northern Indiana
mr_belvedere Offline
super gas
super gas
Northern Indiana
I recall seeing fasteners similar to what you are describing and they were from (iirc) the battery tray brackets.
Re: Help with small bolts-"67 GTX Body assembly,please [Re: mr_belvedere] #770914
08/11/10 09:34 AM
08/11/10 09:34 AM
Canfield,Ohio,USA
gassy66 Offline OP
gassy66  Offline OP
Canfield,Ohio,USA
Yeah! Battery Tray! that makes sense-corrosion
resistant. Thanks for reply
Re: Help with small bolts-"67 GTX Body assembly,please [Re: gassy66] #770915
08/11/10 09:50 AM
08/11/10 09:50 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
I think all the battery tray fasteners are 5/16-18 thread
the only thing I can think off the top of my head thats 1/4-20 - is radiator mounting, lower rad support to K-frame and under hood electrical device attachments
Is there a body color panel between the frt bumper and grille ?
if so they would be 1/4-20 as well
Re: Help with small bolts-"67 GTX Body assembly,please [Re: gtx6970] #770916
08/11/10 10:10 AM
08/11/10 10:10 AM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
There is a small bolt with a sharp pointy end and copper captive washer that holds the ground strap to the firewall.
Re: Help with small bolts-"67 GTX Body assembly,please [Re: Dave Watt] #770917
08/11/10 08:10 PM
08/11/10 08:10 PM
western PA
mopar4ya Offline
mopar4ya  Offline
western PA
Can you post a picture of these bolts??
Dan
