Re: rattling noise from rear brakes
[Re: 68bb]
#770566
08/10/10 11:17 AM
08/10/10 11:17 AM
Posts: 75,095 A Banana Republic near you.
JohnRR
yes, loose parts ... are you sure it's not in the tire ? Sometimes the spring that holds the shoe to the backing plate will pop off if it's not seated properly, easy to tell that , look at the backing plate and see if the pin for it is missing or not seated flat against the plate.
[Re: 68bb]
#770569
08/10/10 11:55 AM
08/10/10 11:55 AM
Challenger 1
Cincinnati, Ohio
thanks John, I'll get the wheels pulled off soon and look for that.
I think you misunderstood what John said, you don't have to pull wheels to check for what John said.
Gonna have to pull wheels either way to repair them.
[Re: JohnRR]
#770570
08/10/10 12:10 PM
08/10/10 12:10 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Or loose center cap...(if you have one)
[Re: OzHemi]
#770571
08/10/10 01:26 PM
08/10/10 01:26 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I had a self adjuster break and fall off inside the drum, and you could hear it when you spun the wheel.
I also just recently had to do a brake job on my Dakota...it's a rear disc set up, but the parking brake is a shoe in hat design...the lining for the parking brake came off, and was making a clicking noise inside the rotor.
lots of things to check that COULD be it...only way to find out for sure is to pull the wheel and drum
**Photobucket sucks**
