Page 16 of 46 1 2 14 15 16 17 18 45 46
Re: Taking it to the next level? Wow! [Re: bremotorsports] #77062
07/04/08 04:58 PM
07/04/08 04:58 PM
New Jersey Bada Bing
bremotorsports Offline
#6
Re: Taking it to the next level? Wow! [Re: bremotorsports] #77063
07/04/08 04:59 PM
07/04/08 04:59 PM
#7
Re: Taking it to the next level? Wow! [Re: bremotorsports] #77064
07/04/08 05:00 PM
07/04/08 05:00 PM
#8
Bill Rolik
Re: Taking it to the next level? Wow! [Re: ECS] #77065
07/04/08 05:12 PM
07/04/08 05:12 PM
Dave,
You are slipping:
You don't have your entire broadcast sheet tatooed on your arm? I will let it slide this time!
I will check my available info at the warehouse tomorrow for the "65" hose.
Bill Rolik
Re: Taking it to the next level? Wow! [Re: bremotorsports] #77066
07/04/08 05:20 PM
07/04/08 05:20 PM
USA
E
ECS Offline
David Walden
ECS  Offline
David Walden
E
USA
Hi Bill,
Do you have ANY information on the correct upper hose for an A/C car? I can only find the original ones that have the hump that slopes back down towards the radiator inlet. What is the application for the ones with the hump? What is the purpose for that hump? That is the only style I have seen on original A/C cars. Even if you want to throw out the black Charger from the mix, what about the red Challenger? That car only had a couple of oil changes in it’s life. And what about the picture of the vehicle on the assembly line. What was the number for that particular style hose? It is shaped exactly like the one I found for an my A/C application. If the #257 was supposed to be for the A/C equipped cars, why do they all appear to be shaped different than the ones we are seeing on these non A/C cars? Are the people posting these pictures of the #257 absolutely sure that these hoses are the factory assembly line units? They could still appear to be original even if they were replaced 35 years ago. I know the same logic could be used for the cars I saw at Richard’s place but that assembly line photo hose is certainly correct.
Re: Taking it to the next level? Wow! [Re: ECS] #77067
07/04/08 05:33 PM
07/04/08 05:33 PM
Dave, et al.
One additional item:
The parts catalogs can be very goofy with many things, including hoses.
An example would be, once again in my own particular case, the 71 340.
For the inlet hose the book (1/72 Edition)reads as follows:
71 All except A-Body:
"w/318,340,360 W/A/Cond. W/Max.Cooling" 3462102
Where is the reference to non-A/C cars? There isn't one printed. Reading this, you would assume that the car was built without one, and the parts counterman and/or customer is on his own for a hose. FYI, non-A/C cars used the 3462102 as well.
Bill Rolik
Re: Taking it to the next level? Wow! [Re: bremotorsports] #77068
07/04/08 05:37 PM
07/04/08 05:37 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
My 70 (St. Louis built) V code Coronet R/T has the original heater hoses on it and they look unlike any that have been posted, unless I missed it. I will try to post a pic later.
MB
Re: Taking it to the next level? Wow! [Re: ECS] #77069
07/04/08 05:41 PM
07/04/08 05:41 PM
I will see what I can find out tomorrow.
Bill Rolik
Re: Taking it to the next level? Wow! [Re: bremotorsports] #77070
07/04/08 05:44 PM
07/04/08 05:44 PM
USA
E
ECS Offline
David Walden
ECS  Offline
David Walden
E
USA
Wild Bill,
You are doing the quick shuffle two step regarding my question. What number is the hose that I have been posting (on the original cars) with the "hump" that angles back down toward the radiator inlet? I am seeing it in A/C cars from 1968 thru 1971. I don't think the body style has anything to do with it as the engines were basically the same. Look at the picture Richard's red 71 Challenger hose that I posted earlier. Do you (or anyone) know what part number is assigned to that hose?
Re: Taking it to the next level? Wow! [Re: bremotorsports] #77071
07/04/08 05:47 PM
07/04/08 05:47 PM
USA
E
ECS Offline
David Walden
ECS  Offline
David Walden
E
USA
Bill Rolik
Sorry Bill! You responded while I was typing.
Re: Taking it to the next level? Wow! [Re: ECS] #77072
07/04/08 06:34 PM
07/04/08 06:34 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
(Mine is at the office so I don’t have access to it right now
Your broadcast sheets are coded for the 57 hose.
Re: Taking it to the next level? Wow! [Re: ECS] #77073
07/04/08 07:22 PM
07/04/08 07:22 PM
East Coast, NJ
fig426 Offline
fig426  Offline
East Coast, NJ
[quote)
Has it occurred to anyone that the incorrect hose has somehow become accepted over time as the correct one?
Dave,, That is the case, as you know, with alot of these cars. Not just the Mopars but the other two also. There are things on my cars that people are going to say are wrong, but that's the way they came. And alot of people have cars like that. Then someone (or two) go and say that it can't be right because they THINK they know every answer to everything on every car.... so... the person doing the car goes and changes it on someone else's suggestion,,,, and,,, history gets changed once again.
Chris from New Jersey
Re: Taking it to the next level? Wow! [Re: fig426] #77074
07/04/08 07:32 PM
07/04/08 07:32 PM
California
sixpaktoogo Offline
sixpaktoogo  Offline
California
I have a 70 340 Cuda, built in Los Angeles, that I am presently restoring. The K-member shows NO sign of ever being painted black!!! Looks to have been bare steel from day one. Car appears to have never been apart previously. Has anyone seen another like this? I know Resto Rick states he has, on his web page! Anyone else?
Re: Taking it to the next level? Wow! [Re: sixpaktoogo] #77075
07/04/08 08:03 PM
07/04/08 08:03 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
One of my O.E.hoses.
Re: Taking it to the next level? Wow! [Re: fig426] #77076
07/04/08 08:33 PM
07/04/08 08:33 PM
USA
E
ECS Offline
David Walden
ECS  Offline
David Walden
E
USA
[quote)
Hello Chris! How are you doing? Thanks for the post. There is something odd regarding the upper radiator hose for an A/C car. Was there a variation hose used for A/C equipped cars at the factory? I have no idea. Barry confirmed that my build sheet (as did Steve a little while ago) shows a 257 hose. Are all of the original A/C hoses on the cars I saw coincidently the exact same AND incorrect? I doubt it. I do know that provisions were made on the assembly line to compensate for the A/C cars. Bolts were also removed and replaced which eliminated the normal paint patterns of the engine. I do not have an absolute opinion on this subject just yet. I am leaning towards the upper hose on A/C cars being like the ones I have documented with the “hump“. Like I said earlier, I have both styles to choose from. I will definitely find the answer to this one over the next few days. This is starting to be reminiscent of another beating I took concerning hood scoops being painted in or out of the car. Check out the attached picture and the big drip hanging from the closest screw. Might just be another “fluke”.
Re: Taking it to the next level? Wow! [Re: ECS] #77077
07/05/08 07:11 AM
07/05/08 07:11 AM
www.mmcdetroit.com
MMC Detroit Offline
MMC Detroit  Offline
www.mmcdetroit.com
The following quotes from this post sum up what the ICCA has been attempting to drive into the hobby relating to judging/ validating vehicles.
"I just have a difficult time understanding how some people have the ability to easily notice inconsistencies in some products but seem to be blind to the variations that exist within their own selections."
"Has it occurred to anyone that the incorrect hose has somehow become accepted over time as the correct one?"
"Do you see the confusion that is starting to developed here? Chryslers own parts application book seems to be contradicting what came on their own cars. How can anyone be absolutely sure what is correct unless you were lucky enough to still have the original hose when you took possession of your car?"
"That is the case, as you know, with alot of these cars. Not just the Mopars but the other two also. There are things on my cars that people are going to say are wrong, but that's the way they came. And a lot of people have cars like that. Then someone (or two) go and say that it can't be right because they THINK they know every answer to everything on every car.... so... the person doing the car goes and changes it on someone else's suggestion,,,, and,,, history gets changed once again."
I have seen thousands of vehicles that have variations from one to another. I'm sure we will all see many original variations as we begin to look closer at details that did not concern us in the past now that we are all doing our best to make our cars as accurate as possible.
Dave Wise
MMC / ICCA Detroit
MMC/ ICCA Detroit. The Motor City or where ever there is Mopars
Re: Taking it to the next level? Wow! [Re: MMC Detroit] #77078
07/05/08 08:09 AM
07/05/08 08:09 AM
PA
P
PLATINUM6BBL Offline
P
PA
I know this is from the wrong year but here is the rad hose on my Dads' 6846 mile 66 300 2dr
1969-1/2 A12 LOH Road Runner A4 w/ M6S
13.34 at 104 PSMCDR 9/06 in Mopar Action 8/07
12.95 at 105.94 F.A.S.T. 11/06
Re: Taking it to the next level? Wow! [Re: PLATINUM6BBL] #77079
07/05/08 08:11 AM
07/05/08 08:11 AM
PA
P
P
PA
nudder
Re: Taking it to the next level? Wow! [Re: sixpaktoogo] #77080
07/05/08 01:51 PM
07/05/08 01:51 PM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline
I have a 70 Challenger, that has a gray painted K-frame. Car was never apart before I got it, also had the part number stamped right on top of the gray paint. I'm sure it came that way, so I restored it the same way. Of course I get questioned all the time, but I have "before" pictures to back it up.
Re: Taking it to the next level? Wow! [Re: MMC Detroit] #77081
07/05/08 06:55 PM
07/05/08 06:55 PM
USA
E
ECS Offline
David Walden
ECS  Offline
David Walden
E
USA
Dave Wise
MMC / ICCA Detroit
Hello Dave. Good to hear from you on this subject! If you have been following this post (that took a u-turn with these hoses)you can certainly see some of the differing opinions on the subject. There are people who say the A/C hose is incorrect for my Challenger but based on what? If they know the part is wrong, they MUST know what makes it wrong and/or it's correct application. No one can answer why these A/C cars have this hose with the hump in it. This particular hose is not a reproduction item so where did it come from? How did all of these A/C cars get the exact "incorrect" hose that is not a reproduction example. I personally think that the cars with A/C had this particular hose for extra clearance around the belts. In the picture posted by PLATINUM6BBL, his hose even shows the "hump"characteristic like all the other A/C cars I have documented. As you can see, everyone here is using NON A/C examples to substantiate the #257 hose for A/C cars. Dave, do you (or anyone else) have ANY engine photos of 1970 big block original cars that are A/C equipped but with the regular #257 hose on them?
