Proper Fuel Fitting?
#770154
08/09/10 10:10 PM
08/09/10 10:10 PM
Posts: 352 Pennsylvania, USA
Big_Fish
Pennsylvania, USA
Can anyone recommend a Y or T Fuel fitting? I have a BG Regulator with 1/8" NPT female threads for a gauge. I want to run the gauge at the regulator so I can see the pressure while making any adjustments. I want to add a steel braided line to a second gauge mounted on my cowl so I can monitor fuel pressure while also in the seat. I found this one but I don't know if it will work... http://www.jegs.com/webapp/wcs/stores/se...archTerm=240855Thanks Adam
Re: Proper Fuel Fitting?
[Re: Big_Fish]
#770155
08/09/10 10:25 PM
08/09/10 10:25 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
sure then 1/8" to -3 or -4 fittings screw into block. they also come in 45's and 90's this style or this with a 1/8 short nipple
[Re: Big_Fish]
#770156
08/09/10 10:30 PM
08/09/10 10:30 PM
Posts: 7,506 Az
Crizila
Az
Sure it will work. Anything with pipe threads can be adapted to just about anything - including AN fittings - per Hemi-Freds example.
Fastest 300
[Re: HEMIFRED]
#770157
08/09/10 10:44 PM
08/09/10 10:44 PM
HEMIFRED
SOUTH JERSEY
you can use one end of the T for the AN fitting and the other just have a nipple be screwed into the gauge
home of the Sox and Martin Hemi Duster
[Re: Big_Fish]
#770159
08/09/10 11:01 PM
08/09/10 11:01 PM
HEMIFRED
SOUTH JERSEY
ok then here's what you need to use.put it anywhere at a carb.it screws between a line and fitting. its called a "PRESSURE ADAPTER" AN MALE TO AN FEMALE comes in -4 and -6 sizes
