Re: Do I have a forged or cast crank?
[Re: 1970RT]
#769690
08/09/10 09:44 PM
08/09/10 09:44 PM
Posts: 398 Texas
70Runnerdude
Texas
[Re: Alexdodge]
#769696
08/10/10 12:30 AM
08/10/10 12:30 AM
Posts: 4,150 lewiston, ID
cornucopia
lewiston, ID
yup. it's forged...273 or 318. the 340 had the rod journals cross drilled. interchageable with a balance job.
[Re: wyotech_cuda440]
#769698
08/10/10 09:25 AM
08/10/10 09:25 AM
Posts: 75,125 A Banana Republic near you.
JohnRR
Regardless of the P/N, that is a forged crank. It's easily determined by the wide parting line because it was slammed between two dies in a forge. If the two dies hit each other, the forge will destroy itself, so the dies stop short and leave a wider seam. The cast crank has a thin parting line, because the casting molds are held together tightly so the molten steel doesn't run out.
What he said ... it doesn't matter what part number is on it , it's a FORGED CRANK
[Re: JohnRR]
#769700
08/10/10 02:00 PM
08/10/10 02:00 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
I totally agree. The pictures don't lie. Now............. Why the cast crank P/N? ![](/ubbthreads/images/graemlins/shruggy.gif)
And the 1st person that says "I've seen.... " ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: Commando1]
#769701
08/10/10 04:15 PM
08/10/10 04:15 PM
Posts: 26,032 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I, too, am curious as to the part number, is it stamped or written or is the number raised?
