I'm building an almost stock 383 for my super bee.
I have a year correct short motor already.
The short motor has flat top pistons with no relief and has previously been used with 906 heads.
I will be using stock 68 hi po manifolds and a stock intake,maybe a edelbrock performer but definatley nothing bigger.
Carb is likely to be an edelbrock AVS 600.Cam is likely Mopar 484
So....Heads? Should i go for a 906? or a closed chamber head?Or is it worth buying some of the 440 source stealth heads?
Performance is not a mega priority,but i'd like to make the best of what i'm gonna use.
This is a street car running an auto box and 3.23 gears.I don't want a lopey idle and i'd like some vacuum for my brakes also.
over to you guys....
