Re: Taking it to the next level? Wow!
[Re: ECS]
#76943
06/26/08 03:23 PM
06/26/08 03:23 PM
Posts: 17,528 Las Vegas, NV
6bblgt
Las Vegas, NV
Yes Troy! Correct you are. Now lets see if you can answer this question:
Where did yours come from?
Dave, Yours is obviously the Tigers vs. Indians box score from the privious night. Indians won!!
Troy's pic is from the following season.
![](/ubbthreads/images/graemlins/grin.gif)
[Re: moparo]
#76945
06/26/08 07:23 PM
06/26/08 07:23 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Alan
The dip line inside the cars has been done.
Gosh !!! I wish I had the dinero to do my cars like this...... I'll make due. ![](/ubbthreads/images/graemlins/grin.gif)
All you guys rock................
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: beepbeep]
#76947
06/26/08 08:23 PM
06/26/08 08:23 PM
hemi68charger
Houston, Tx
OK Dave... Welllllll, what's the Vehicle Traveler form? Is that the form in question in the pictures? America's dying to know here !!!! Did I get it right about the "items/inventory" associated with the car in the trunk upon delivery?.....
Troy
It tracked problems.
Soooo, I was wrong with my answer? ![](/ubbthreads/images/graemlins/bawling.gif)
[Re: hemi68charger]
#76948
06/26/08 11:01 PM
06/26/08 11:01 PM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
Nope. You are 100% correct. I spoke extensively tonight with Dave Stuart about this very subject. He has the most unbelievable source of paperwork and factory documents from the sixties and seventies that I have ever seen. It is truly remarkable what you can obtain when you are a bigwig at Chrysler for 20+years. He said that the factory shipped items in the trunk that are (even today) referred to as "loose items". These are not normally covered by the factory warranty and include pieces such as floor mats, front license plate holder, trim rings, manuals, etc.... The vehicle traveler form was used as a quick reference to keep all the items and other paperwork married with the car. I asked Dave what he thought about it being a "problem" form and he said it would not have served that particular purpose. The factory used a separate form that listed problems found with the car. That was used as a reference for the final inspection of the vehicle before it left the manufacturing facilities.
[Re: ECS]
#76949
06/26/08 11:12 PM
06/26/08 11:12 PM
Posts: 27,485 So Cal
autoxcuda
So Cal
[Re: beepbeep]
#76952
06/27/08 12:41 AM
06/27/08 12:41 AM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
So... please explain why a front glass stabilizer track guide would be in the trunk?
Being that I didn't put it there I can't answer that question. I also wouldn't know why a doctor's appointment was written on a factory invoice I had seen but I am sure that was not a factory mandated procedure. If appears that someone ADDED that section you pictured of the vehicle traveler sheet. It certainly was not part of the original sheet. You also can't use one sample to justify every one. I have seen quite a few that had only the top row of processed information filled in. Look at the sample that was said to be Steve Julianos. Nothing but the top row of information is filled out. (It is identical to the top row of a build sheet.) Why would they put a "problem" form with the car if there were no problems to be listed on the sheet? These forms were not considered vague with regards to their specified function. Chrysler was very precise with the paperwork and the intent of their purposes.
[Re: autoxcuda]
#76953
06/27/08 12:52 AM
06/27/08 12:52 AM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
99% it's Steve Juliano's 71 Hemi Charger survivor. I think I watched this picture being taken.
Are you sure that Steven's car is a survivor? (Please, just ignore my joking sarcasm!) I noticed there is about the same amount of paint on his rear seat braces as there are on my white Challenger. I was informed that we applied the paint there too heavy! How is it that my "details" are the only ones that seem to be scrutinized while everyone else's (exact same features) go unnoticed? ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: beepbeep]
#76955
06/27/08 01:25 AM
06/27/08 01:25 AM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
original.
And there in lies the problem with the scenario. Original vs. being altered by someone after the fact but... being presented as an unaltered original!
[Re: ECS]
#76956
06/27/08 03:26 AM
06/27/08 03:26 AM
autoxcuda
So Cal
Enviroment and conditions make a big difference in looking at original examples. My Barracuda has been registered, driven, and used hard since 1968. Just a So Cal driver. Still the trunk looks pretty decent, but it doesn't look as shiney as the 71 Charger R/T Survivor.
Mine doesn't look as shiney as it did in 1993 when I got it. Unless these cars are in a excellent climate controlled enviroment, they deterioate and de-vole. The pictures show that.
It does leak moisture from the vinyl top molding screws ever so slightly. That's what's given it surface rust under the dutchman and dullness on the X-brace. Still, it doesn't have pock mark on the floor.
You can see the dip line on the X-brace and outer hinge support. And see the spraying direction of the RR1 Maroon. Nothing is even dusted or cleaned here, so it looks pretty dull. For all the un-mentionable wear and tear it couldn't have been too thin in there.
(ignore the hoaky speaker install)
![](https://board.moparts.org/ubbthreads/upload2/4514804-PICT1985.JPG)
[Re: Blues_Cuda]
#76957
06/27/08 10:01 AM
06/27/08 10:01 AM
Posts: 11,854 Georgetown Ontario Canada
anlauto
Those maroon pictures show the "lack of paint" I was referring to, while the purple car shows (somewhat) the oppisite. Proof is in the pudding. The amount of white paint on the Challeger should only duplicate the amount of paint that was found on the Challenger in the before shots. I am fascinated with the "before" and "after" firewall shots because it show just how anal you guys are about the squeeze-out of the sealer. It appears pretty darn near right-on to the original photo. I mearly stated that compared to cars I've seen ...the white car appears to have lots of paint in the trunk area....If you could post "before" shots... ![](/ubbthreads/images/graemlins/shruggy.gif) I've stated in my last PM that I'm floored by the amount of time and detail that goes into these OE Gold cars in areas that nobody will ever see. I had no idea what the insides of the green Cuda looked like ![](/ubbthreads/images/graemlins/shock.gif) having only seen it from the outside. Keep up the GREAT work everybody ![](/ubbthreads/images/graemlins/thumbs.gif)
CHECK OUT MY NEW WEB SITE !
[Re: ECS]
#76960
06/27/08 01:22 PM
06/27/08 01:22 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
This is awesome info and great pics. Some people are just argumentative and are playing Devil's advocate. I don't think, other than maybe early on, their has been any personal attacks on your project, efforts, skills or even results. The more things come to light and the more we discuss it the better the information data base becomes. Things thought to be facts 10 years ago are now discredited. We continue to grow. Share your story and info and 99% of it will be appreciative, even grateful and better off for your efforts to share your experiences. You posess a level of detail that very very few have the patiences to accomplish, the skills, although extraordinary are only a small part of your achievements, the patiences is just not there for most of us. ![](/ubbthreads/images/graemlins/Twocents.gif)
Careful, your character's showing!
[Re: anlauto]
#76961
06/27/08 02:20 PM
06/27/08 02:20 PM
autoxcuda
So Cal
Those maroon pictures show the "lack of paint" I was referring to, while the purple car shows (somewhat) the oppisite. Proof is in the pudding. The amount of white paint on the Challeger should only duplicate the amount of paint that was found on the Challenger in the before shots....
But define "before": 2-3 year ago pictures of a 35+ year old car or the pictures of the car the day it was purchased by the original owner?? I think you have to be careful with some references because this stuff ages.
This white Challenger certainly did not live as pampered of a life as the FC7 Hemi 71 Charger R/T.
At some point this is a Catch 22. If a car is so perfect to get the best before restoration references, it probably shouldn't be restored anyway.
