440 mechanical water pump and housing recommendations #769136
08/08/10 09:31 PM
08/08/10 09:31 PM
Elverson, PA
prettyslick65 Offline OP
Elverson, PA
I was looking for recommnedations on a high flow water pump and housing for a stock 440. I looked at all the major choices and honestly can't make up my mind. I have a stock 440 now, but at some point I hope to re-build it to run mid 12's at the track occasionally, so my purchase now would be used for that application. Any opinions, experiences out there? Thanks.
Re: 440 mechanical water pump and housing recommendations [Re: prettyslick65] #769137
08/08/10 11:18 PM
08/08/10 11:18 PM
IN
ahy Offline
ahy  Offline
IN
I'm running the MP housing and MP high volume pump. The pump is about 7% overdriven with my pulley setup. It has worked great. 496 "B" with AC.
Re: 440 mechanical water pump and housing recommendations [Re: prettyslick65] #769138
08/08/10 11:40 PM
08/08/10 11:40 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Milodon water pump and thermostat.
