Re: new car excellent home for the R5 small block
[Re: Hitman340]
#768869
10/05/10 12:37 PM
10/05/10 12:37 PM
Posts: 2,584 sycamore,ohio
BobsProFab
sycamore,ohio
this is a straight on view of template 4 trimmed at the body line.
#4 trimmed to body line looks much better
[Re: Hitman340]
#768873
10/06/10 09:15 PM
10/06/10 09:15 PM
Posts: 437 south central pa
bdaz smblk
south central pa
Good work Jeff and good choice Bob.Great job on the car Bob looks super sweet.Can't wait to see what it runs.Kenny
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
[Re: poppaj]
#768885
10/11/10 07:09 PM
10/11/10 07:09 PM
BobsProFab
sycamore,ohio
Bucky water jetted out my adjustable wicker and tabs today
What is that part for.
yes its for the rear of the wing.
Jeff will bend the tabs on a 90 degree and they will bolt to the bottom side of the rear part of the wing and the wicker bolts to them
with the double holes you see on the wicker and the tabs (3 different positions)will allow me to adjust the height of how high i want the wicker sticking past the top of the wing for less or more down force
