Re: Shelf life on racing fuel
[Re: Big_Fish]
#768173
08/08/10 12:02 AM
08/08/10 12:02 AM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
I've had 5 gallons of C16 for over a year and didn't put any fuel stabilizer in it or anything. Any chance I can cut this with new fuel and still use it? Just wondering if it's any good or should I just toss it (lawn mower use etc). Thanks
I wouldn't use it. Some other people will tell you it's fine, but I have seen first hand how poorly old race fuel performs on the dyno. For the relatively small cost of 5 gallons, it's not worth hurting your motor over it.
MB
[Re: Big_Fish]
#768174
08/08/10 12:03 AM
08/08/10 12:03 AM
Posts: 43,309 Bend,OR USA
Cab_Burge
What type container was it store in, plastic, metal fuel barrel or can?
[Re: jamesc]
#768176
08/08/10 04:30 AM
08/08/10 04:30 AM
Challenger 1
Cincinnati, Ohio
run it
Race gas already has stabilzers in it, run it. I've stored cars and small engines with it for 20+ years now.
[Re: tboomer]
#768180
08/08/10 08:25 AM
08/08/10 08:25 AM
Posts: 6,295 U.S.
moparniac
U.S.
wouldnt this matter from what type pf container used and geograpic location/ yearly climate of where you live.
Mopar Performance
[Re: jamesc]
#768182
08/08/10 08:55 AM
08/08/10 08:55 AM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
what would you expect from a company that sells fuel? fyi the "lighter" elements don't necessarily carry a high octane rating, working in a refinery for 15 years you do learn a couple things. imho if you had a engine detonating on Maximal (116 Octane) that was only nine months old and new fuel corrected that there were other considerations going on. iirc the TEL they put in race fuels has a great impact on octane doesn't have a high vapor pressure. not that fuel doesn't degrade over time but i've used race fuel that's two years old with no noticeable issues and he's talking about cutting it as well. i wouldn't do it on a prostocker but imho for most applications it's a non issue.
They don't put a "use before" date on the can and they don't say to throw it out -they are just making a recommendation. They could also say something like "buy as much as you can-it will never go bad". That might be good for sales, no? I never worked in a refinery and I am no chemist and respect your opinion, just relaying personal info, that's all. If you really want to see fuel degrade,though, try using old Q16 . I did miss the part that the OP mentioned that he would be cutting it. That would mitigate the circumstances.
MB
[Re: moparniac]
#768183
08/08/10 09:23 AM
08/08/10 09:23 AM
Posts: 5,875 communist bloc of new jersey
jamesc
yes, many race fuels are photosensitive (UV rays from sunlight degrade them) so keeping them in a dark, cool, dry area is best. i used to be able to get a drum (steel) directly from the refinery being i was an employee but they won't do it anymore. the last drum i brought was in a poly drum which i don't particularly care for. it's probably no issue with methanol but for gasoline i very much prefer a steel drum. methanol is hygroscopic which means it will absorb moisture right out of the air so it's very important to keep alky sealed up tight.
[Re: HPMike]
#768184
08/08/10 09:26 AM
08/08/10 09:26 AM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
It took me over a year to burn up the 55G drum of sunoco 110 and the last 5G the car ran the same number as it did with the first 5G
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: jamesc]
#768185
08/08/10 10:59 AM
08/08/10 10:59 AM
Challenger 1
Cincinnati, Ohio
Except storing fuel in plastic drums. Too much vapor escapes through plastic,imo.
Wow, I din't think plastic 55 gal drums were legal for fuel storage. Do the plastic drums have DOT and a number molded into them?
All the plastic drums I've looked at over the years were not DOT legal for flamable liquids.
IMO plastic is the worst large storage container for race gas, big myth about rust. Keeping it in a cool dry place is the key, to keeping moisture out, hence rust. It's not OK sitting out on the side of the house seeing the temp changes day after day. I've seen it, as I've been selling race fuels since the 80s.
[Re: Challenger 1]
#768187
08/08/10 11:36 AM
08/08/10 11:36 AM
Posts: 3,695 nc
emarine01
nc
All fuels are not created equal, so the best way to figure anything out is do a simple test, pour the fuel into a clear glass jar and look at it into the light, compared to a fresh sample of the same fuel, as they say a pic is worth a thousand words, Check for color and clarity, if the fuel is cloudy don't use it in a race engine, my lawn tractor is addicted to old 100ll ave gas another good test is to store a QT of the fuel you choose to run in a sealed glass jar and store it for six Mo, then check the bottom of the jar for sediments and phase separation, just cause you paid good bux for it does not mean its the best fuel
[Re: Big_Fish]
#768189
08/08/10 12:08 PM
08/08/10 12:08 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
Last time I had my motor on a dyno I compared fresh c-16 with fuel that was over a year old. My results were no change between the two fuels.
[Re: Big_Fish]
#768190
08/08/10 12:17 PM
08/08/10 12:17 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Thanks for the feedback. I forgot I had a 5 gal plastic fuel jug in the garage. I thought it was empty until I had to move it to get something. It was in a dry environment but I think I'll just cut it and not completely chance it. 1:5 ratio and if anything negative is noticed I'll repost the info. Thanks again.
If it's been stored in a plastic jug....I wouldn't use it period....not even mixed.
Rickster
