2002 Neon Rack & Pinion replacement ? #768031
08/07/10 09:55 PM
08/07/10 09:55 PM
Middletown , Ohio
DonnieLawson Offline OP
Middletown , Ohio
My daughters 2002 Neon has a loose rack & Pinion , I can move the tires slightly side to side without moving the steering wheel. Outer tie rod ends are good .
How hard is it to replace the unit , I have a 4 post lift and a fairly well equipped garage to do this.
Or should I try to change the inner tie rod ends first ?
Does the engine and cradle need to be dropped or can I change it while its still in the car ?
Donnie
Re: 2002 Neon Rack & Pinion replacement ? [Re: DonnieLawson] #768032
08/07/10 10:59 PM
08/07/10 10:59 PM
md
mopars4ever Offline
mopars4ever  Offline
md
My daughters 03 needed a tie rod. Might be worth checking out before replacing the rack.
