Need help with 8 3/4 id #768004
08/07/10 09:11 PM
08/07/10 09:11 PM
Wisconsin
moparkid88 Offline OP
Wisconsin
I hope the picture works out ok i think the rear end has backing plate dimension of 59ish i would like to swap it into my 1973 dodge charger and i know i gotta mod the mounting flange. I was wondering if someone knew the year or anything so i know what parts to order as far as seals and bearings.Any help is greatly appreciated. Thankyou.
Re: Need help with 8 3/4 id [Re: moparkid88] #768005
08/07/10 09:37 PM
08/07/10 09:37 PM
scratchnfotraction Offline
measure the housing from flange to flange(where the backing plate bolts to housing)
whats the wheel bolt pattern? 5 on 4 1/2"? 5 on 5 1/2"?
look along the bottom of the pinion and get the last 3 didgets of the casting # to tell what chunk you have...741-742-489
if you pull the chunk it will have the yr and gear ratio on the edge of ring gear
measure the spring perches center to center for a better guess of what it ut of
all the gaskets and wheel bearings are the same for a stock 8 3/4 unless it has green roller bearings put on it at some time
the only seal that may change is the pinion seal..depends on the chunk you have as to pinion size
the chunks swap a round expet for the real older ones and matching the carrier to the correct case bearings ect..
that will get you started on IDing it
post the measurement and #s for a better guess
dont forget to sand blast and paint it
Re: Need help with 8 3/4 id [Re: moparkid88] #768006
08/08/10 07:13 AM
08/08/10 07:13 AM
Morningside, Long Island
scatcity Offline
scatcity  Offline
You may of measured and inch and change too much, re-check that as previous poster stated. B & E body rears are in the 57ish & change range flange to flange. As you know, in order to put that rear into your 73 would most likely involve perch mods, narrowing the axle tubes, and/or offset shackle drama. If the price is right, and, it's a 489 or 741 casing, grab it just the same. As far as I know, there are no date stampings on the axle housing, anyone? In my deranged opinion, you're better off obtaining a 71 and up B body specific 8 3/4 and do what you see fit with the case and gear ratio of your choice.Hopefully you overmeasured and its a keeper.
Re: Need help with 8 3/4 id [Re: scatcity] #768007
08/08/10 08:05 AM
08/08/10 08:05 AM
looking at the pic,it seems to be sitting upright and the perches are on top of the axle tube
that means its from a truck,the shock mounts may indacate it from a 65-71 maybe
truck housings are the same a c-body housings as far as width
I have a couple 72 4x4 truck with 5 on 5 1/2" WBP and a 67-polara/E-body size IIRC
if its an early truck you may luck up and have a 3.91 sg in it
Re: Need help with 8 3/4 id [Re: moparkid88] #768008
08/08/10 09:33 AM
08/08/10 09:33 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Ever thought of using the achieves????
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Need help with 8 3/4 id [Re: MoparforLife] #768009
08/08/10 02:12 PM
08/08/10 02:12 PM
Wisconsin
Wisconsin
Ok i checked the casting on the 3rd member it is as follows.. 2881489 and flange to flange is 59ish welding perches is no big deal but i was thinkin if the axle is a touch to long i can get wheels perhaps with a bit of less offset im not lookin for concours here im just a poor boy lookin for cheap upgrades. the gear ratio said 3.23 and feels to be a sure grip! so thats great cuz i now have 2.71 open.
Re: Need help with 8 3/4 id [Re: moparkid88] #768010
08/08/10 02:37 PM
08/08/10 02:37 PM
its from a truck
59" flange to flange is a truck or C-body
perches are on top of the axle tube and should be 43" centers
489 has a crush sleeve
most likly going to be to wide for your car
how wide flange to flange is the one in you car?
it can be done with rim offset up to a point
Re: Need help with 8 3/4 id [Re: scratchnfotraction] #768011
08/08/10 03:45 PM
08/08/10 03:45 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
That rearend is out of a van. The shock mounts are a dead give-away.
Re: Need help with 8 3/4 id [Re: DoctorDiff] #768012
08/08/10 04:15 PM
08/08/10 04:15 PM
Wisconsin
Wisconsin
the one in my car is 57.8 according to tech archives and that seems close i just measured mine. According to that tires would stick out half inch per side if the distance between flange and the hub is the same, correct?
Re: Need help with 8 3/4 id [Re: moparkid88] #768013
08/08/10 11:02 PM
08/08/10 11:02 PM
be carful in the archives..one of those charts is wrong..
but yea sound like a 1/2" could be done with back set on rims no problems
and may only be 1/4 per side
good luck with the swap
