He's can be hard to reach on the phone...Email him or PM him on here....
He usually has a end of the year special if he can get enough entry's.
I have done this twice, and he has the best prices on Indy stuff.
As far as flow numbers go, he should get 350ish cfm out of those heads.
I ran a set of -1's he worked on that ran good.
He also performed the port work on a stock set of Hemi heads...ended up getting 460cfm out of stock valve size, stock port Hemi heads
He has a great following here, and stands behind his work..
