Re: bleeding brakes question
[Re: chache876]
#767858
08/07/10 08:08 PM
08/07/10 08:08 PM
RapidRobert
hook em up/bench bleed the M/C/ bleed one half (fronts or rears) at a time and I'd start w the discs up & get them squared away then the rear. May need to pull/hold the pin on the prop valve if yours has one (might be on 73 up)
