oil and temp send unit #767719
08/07/10 03:28 PM
08/07/10 03:28 PM
louisiana
mopar70charger Offline OP
louisiana
i have a 1972 400 big block rebuilt and doing last minute replacements on these few parts and can't seem to get it correct...i am trying to install both temperature and oil sending unit...the problem is that o'reilly's auto has both parts as oil sending unit as S330 part number but its treads are to big so is the canister itself, the temperature sending unit is part number wt127 it also is small and what appears to be incorrect..i have a temperature switch located by water neck where the heater hose nipples are located and the temp switch in the block is alot bigger treads and overall bigger in diameter..PLEASE HELP IF YOU CAN WITH THIS
Re: oil and temp send unit [Re: mopar70charger] #767720
08/07/10 04:58 PM
08/07/10 04:58 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
BBs used two oil switches one gauge the canister and small light.The temp sender they had 3 for sure.One small for gauge and a large one light.I had an Imperial that had one that had 2 blades sticking up.All the senders have the same thread size.Temp sender Ive seen different size holes on the pump housing.Is this a motor home block?They might be different.My Imperial had signal sentry that had a sender for oil on the passanger side of block also.Rocky
Chrysler Firepower
Re: oil and temp send unit [Re: therocks] #767721
08/07/10 07:25 PM
08/07/10 07:25 PM
louisiana
louisiana
MY TEMP SENDER DOES HAVE THE 2 BLADE LIKE CONNECTORS ON TOP , I CURRENTLY DON'T HAVE NO OIL SENDER INSTALLED SO I DONT KNOW WHICH ONE GOES THERE AS I PICKED UP ONE AT A LOCAL PARTS STORE BUT THE TREADS AND SIZE OF THE UNIT WAS TO BIG.. AND THIS IS GOING IN A 1970 DODGE CHARGER BUT HAS A 72 400 BB ENGINE IN IT..
Re: oil and temp send unit [Re: mopar70charger] #767722
08/07/10 07:31 PM
08/07/10 07:31 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The op switch like I said goes directly in the block and there are only 2 and they all have the same thread size.Make sure someone didnt screw an adapter for a mechanical gauge in the hole.The temp sender if you changed housimgs that might be the problem.What connector does your harness have?A lot of the housings have a hole for the sender and a plug that is a different size on the other side.That way either sender fits.Rocky
Chrysler Firepower
Re: oil and temp send unit [Re: therocks] #767723
08/07/10 07:48 PM
08/07/10 07:48 PM
louisiana
louisiana
ON THE BACK OF THE DRIVERS SIDE BLOCK THERE IS JUST THE TREADS WERE ONE GOES I ASSUMING NO ADAPTER BUT ON THE PASS SIDE OF BLOCK THERE IS SOME SORT OF FITTING SCREWED INTO THAT PORT HOLE...ARE YOU SAYING YOU HAVE TO PUT TO OF THE SAME OR 2 DIFFERENT TYPES OF OIL UNITS IN REAR I AM JUST CONFUSED ON IT ...LIKE I SAID I WENT TO GET ONE AT O'REILLY'S BUT WHEN I TRIED TO INSTALL IT ON THE DRIVERS SIDE PORT THE THREADS ON THE OIL UNIT WAS A LITTLE TO BIG...I READ SOMEWHERE EARLIER THAT THERE ARE 2 DIFFERENT SIZES OF THE SE UNITS BUT I DONT KNOW THAT FOR SURE... THE TEMP UNIT IS ANOTHER PROBLEM I DID SAME THING THERE AND IT WAS WAY TO SMALL I ONLY SEE ON THE WATER PUMP HOUSING WHERE THE WATER NECK AND THE HEATER HOSE NIPPLES ARE LOCATED IS NEXT TO WHERE THE TEMPERATURE SENDER UNIT IS AND ITS THE ONE THAT HAS THE 2 BLADES ON TOP FOR THE CONNECTION
Re: oil and temp send unit [Re: mopar70charger] #767724
08/07/10 09:48 PM
08/07/10 09:48 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
the oil pressure gauge should go into the hole on the passenger side a plug goes into the driver side. Might not matter though witch way it goes. The oil gauge has a big canister on it the oil light has a small sending unit. I am guessing that 72 came out of a c-body and is set up for hot and cold lights in the dash. you might have two temp gauge senders and no oil gauge sender. You might want to go with after market manual gauges as long as you in there.
Re: oil and temp send unit [Re: bboogieart] #767725
08/07/10 11:56 PM
08/07/10 11:56 PM
louisiana
louisiana
I DECODED THE ENGINE AND IT SAYS A 72 CHARGER BASED ON THE NUMBERS ON THE BLOCK..CURRENTLY THEIRS A PLUG ON THE PASSENGER SIDE , ARE YOU SAYIN PLUG THE DRIVERS SIDE AND INSTALL ON OIL SENDER ON PASS SIDE..
Re: oil and temp send unit [Re: mopar70charger] #767726
08/08/10 12:36 AM
08/08/10 12:36 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Yes the sending unit will fit better. please turn off the caps. It's considered yelling and impolite as well as hard to read. Thanks.
Re: oil and temp send unit [Re: stumpy] #767727
08/08/10 12:39 AM
08/08/10 12:39 AM
louisiana
louisiana
sorry for that , thanks a bunch guys will try that..
Re: oil and temp send unit [Re: mopar70charger] #767728
08/08/10 01:50 AM
08/08/10 01:50 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
kinda late hope this helps
pic #1
Re: oil and temp send unit [Re: bboogieart] #767729
08/08/10 01:52 AM
08/08/10 01:52 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
pic #2 is really bad but you should be able to see where the temp gauge sender goes. It's just a lil deal, goes right into the front of the pump. I also have a pump from an air conditioned car and it has both openings in the water pump plugged. So maybe that is why you have a sender in the block.
Re: oil and temp send unit [Re: bboogieart] #767730
08/08/10 01:57 AM
08/08/10 01:57 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Well Stumps looks like you agreed with the wrong guy,although it may be easier. Factory did put em on the drivers side. Been a long time since I looked under this hood.
pic #3
Re: oil and temp send unit [Re: bboogieart] #767731
08/08/10 02:00 AM
08/08/10 02:00 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
stock 68 383
pic #4 same place as the other but again a lousy pic. Funny how a couple frosty beverages can screw with the camera huh?
Re: oil and temp send unit [Re: bboogieart] #767732
08/08/10 02:03 AM
08/08/10 02:03 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
pic #5
the canister for the oil pressure gauge. It screws right in where the other sender goes. Same size threads. Man look at how old that box is. Hmmm wonder how long I had that on the shelf.
Hope this helps.
Re: oil and temp send unit [Re: bboogieart] #767733
08/08/10 03:58 AM
08/08/10 03:58 AM
louisiana
louisiana
that is exactly what i have for my temperature sender on first pic by the water neck housing, do you have any more info on the sender as i cant seem to find one anywhere so far that is...also whee is that iol light located hard to see by the pics....thanks a lot you and the others have been very very helpful...
Re: oil and temp send unit [Re: bboogieart] #767734
08/08/10 06:28 PM
08/08/10 06:28 PM
louisiana
louisiana
can you tell me more info on the temperature sending unit with the blade type connector as that is what i am needing and cant seem to find one ..a part number or what exactly is it from anything at this point...thanks joe
Re: oil and temp send unit [Re: mopar70charger] #767735
08/08/10 06:43 PM
08/08/10 06:43 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You need the correct sender to match the gauge in the car. The old sender on the engine may not be correct for the car you are putting it in. IF you have a gauge there is a smaller hole in the water pump housing for the correct sender. You just have to look for it and then put a plug in the big hole.
Re: oil and temp send unit [Re: stumpy] #767736
08/08/10 07:02 PM
08/08/10 07:02 PM
louisiana
louisiana
i am going to double check, but the problem is , the car is 70 charger motor is 72 charger 400 big block... according to auto parts the temp sender is same on both cars as many different ones as well.. i need the one like in the first pic with the 2 blade type connectors and they dont have that listed for either years..thanks you have been so much help to me stumpy and others
Re: oil and temp send unit [Re: mopar70charger] #767737
08/08/10 07:26 PM
08/08/10 07:26 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Did the original 70 charger have the two pronged sender or did it come with the new engine? I'm a little lost on this point.
Re: oil and temp send unit [Re: stumpy] #767738
08/08/10 08:49 PM
08/08/10 08:49 PM
louisiana
louisiana
thanks for writing back originally it was a 318 car so i am unsure of the motor and its components.like i said it is a 70 charger and has the ralley dash and the gauges but the motor is a 72 charger 400 based on the engine decoding..the 400 was rebuilt and it has the temp sender located by the water neck and the heater hose nipples..it has a temp sender on it and it had the 2 blade style connectors where the wiring connects too..i am about to go look it over with my flash light to see if theres any other places for another smaller temp sender unit..thanks and hope this helped a little more...thanks joe
