Need Help - Crank bushing 4 speed
#766731
08/06/10 12:30 AM
08/06/10 12:30 AM
Posts: 5,141 East Aurora (Buffalo) NY
RoadRunner
OK, less than 7 days until the nats and the motor still isn't in. My replacement motor does not have the bushing installed in the crank for the 4 speed. So I picked up one of the mopar roller bearings. Which way does it go in? One side is chamfered and the other has a relief but square face. I assume that the chamfer side goes into the crank first to account for the radius that is machined in the hole.
Also, it looks like the rollers will run on a different location than the bushing. Will there be any interference between clutch disks and that bearing?
I am using a McLeod street twin clutch.
Thanks.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
Re: Need Help - Crank bushing 4 speed
[Re: Pntastar69]
#766733
08/06/10 07:42 AM
08/06/10 07:42 AM
RoadRunner
Cool. Thanks. I took the day off to hopefully get this thing together and installed today.
[Re: Finoke]
#766735
08/06/10 02:06 PM
08/06/10 02:06 PM
Posts: 456 Santa Barbara, CA
HitIt
Santa Barbara, CA
Put a little film of grease on and tap it in with a wood block. If it's the right size it will go in quite easily.
very clever dinner. appetizing food fit neatly into interesting round pie.
