Re: Mopar Action article on power steering modification? [Re: Pacnorthcuda] #766536
08/17/10 09:43 AM
08/17/10 09:43 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
What is it, some kind of washer to restrict the flow? <snip...>
No its just a washer (of a certain thickness, again I think about .031) to compress the valve/spring assembly in the high pressure line a little more than stock. Simple simple simple.
I just have never tried it or heard from those who have...
Actually, compressing the spring LESS. Target is about 800 PSI. I have now done this on 7 cars with amazingly positive feedback from the owners (plus 2 of my rides and LOTS of pos feedback at the Nats!)
The copper brake-seal washer is a great idea, BTW.
Rick
Re: Mopar Action article on power steering modification? [Re: Rick_Ehrenberg] #766537
08/17/10 09:51 AM
08/17/10 09:51 AM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
Also you say something about the "federal pumps" in the article - what is wrong with them - you did not expand on that.
Don't they have a two stage valve in them to lower line pressure at speed?
Re: Mopar Action article on power steering modification? [Re: 6T6Cuda] #766538
08/17/10 10:55 AM
08/17/10 10:55 AM
Marlboro, NY, USA
Marlboro, NY, USA
Feds are just nonstop hassles, leaks, etc. Plus, most have 200K plus on them now. Same for Thompsons.
I am going to e-mail Tom a pdf of the article, it will take him a while to put it up, it will be at MA tech archive
Rick
Re: Mopar Action article on power steering modification? [Re: Rick_Ehrenberg] #766539
08/17/10 06:41 PM
08/17/10 06:41 PM
Allen, TX
rutro Offline OP
rutro  Offline OP
Allen, TX
Rick,
I finally found the magazine.
So my question is...I pulled out the valve assembly and measured the shims, 0.071" total.
I'm guessing this is off a slant six engine. Should I add additional thickness? I've already made some 0.025" thick shims. Should it be somewhat less than 0.025". I would like to firm it up a little, so I'm not sure how thick a shim to make.
Thanks,Mark
Re: Mopar Action article on power steering modification? [Re: rutro] #766540
08/17/10 07:29 PM
08/17/10 07:29 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: Mopar Action article on power steering modification? [Re: Rick_Ehrenberg] #766541
08/17/10 07:49 PM
08/17/10 07:49 PM
hooziewhatsit Online content
hooziewhatsit  Online Content
Rick
I finally got the box on my '72 W200 adjusted up, and the steering at highway speeds is fairly tight, but takes almost no effort. At a stop one finger can go lock to lock.
It sounds like this mod would increase the effort, which would be awesome
I'll have to dig into my box and see what I find.
Re: Mopar Action article on power steering modification? [Re: rutro] #766542
09/01/10 05:55 PM
09/01/10 05:55 PM
Chicago, IL
P
PLUM_72 Offline
PLUM_72  Offline
P
Chicago, IL
So who has tried this yet?
I pulled the valve out of my Challenger P/S pump and found three .022 shims or total of .066.
So do you add another .062 worth of shims as the article suggests to my already .066, or should I try to approximate the .077 stack up like the article had tested?
1972 Dodge Challenger
Re: Mopar Action article on power steering modification? [Re: PLUM_72] #766543
09/01/10 06:28 PM
09/01/10 06:28 PM
I pulled the valve out of my trucks pump, and found 2 0.011" shims, for a total of 22.
I ground down a washer that ended up right at 0.077, and put that in.
There's a definite difference while stopped and a little more resistance in the turns. Going straight down the highway may be a little better, but it's still not awesome.
I'm thinking about putting the original shims in for ~0.099".
By adding more shims all you'll do is lower the pressure. I would aim for the 77 to start with (but I wouldn't worry about it being exact). If there's too much resistance, take some back out.
Re: Mopar Action article on power steering modification? [Re: rutro] #766544
09/02/10 11:53 AM
09/02/10 11:53 AM
Marlboro, NY, USA
Marlboro, NY, USA
Let me just reiterate a few points...
> I have only tried this on vehicles with Chrysler-built chucks (i.e., "classic" Mopars and older B-vans). I have no idea of the ramifications of doing this on cars with Saginaw chucks (pickups, newer B-vans) but my gut tell me the outcome will be similar. I also dunno about using the reduced pressure with racks.
> Every vehicle I've tried this on (about 9 now) has worked out extremely well with a very noticeable improvement in "road feel". Not magic, but significant. However, if your chuck has 100K, your linkage is sloppy, you have zero caster, and you have 85-series bias-ply tires on 5" wheels @ 22 PSI... ;->
Rick
Re: Mopar Action article on power steering modification? [Re: PLUM_72] #766545
09/04/10 07:33 PM
09/04/10 07:33 PM
Chicago, IL
P
PLUM_72 Offline
PLUM_72  Offline
P
Chicago, IL
Ok update...Had .066 worth of shims stock, added a .020 shim for a total of .086
Is there a difference? Well maybe a slight difference. I was afraid to go more without having gages to see where the pressure went.
It would have been nice for the article to state the shim size in the pump that gave 1400psi. Perhaps there's a relationship that could be calc'd between shims and pressure.
If nothing else it was a good fluid change. I got rid of my ATF/power steering fluid mix that had been in the pump before.
Re: Mopar Action article on power steering modification? [Re: Rick_Ehrenberg] #766546
09/05/10 08:47 AM
09/05/10 08:47 AM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
So this mod will work with the early pumps found on '62-'65 "B" bodies?
Rick
This is the land of the free because of the brave
Re: Mopar Action article on power steering modification? [Re: PLUM_72] #766547
09/05/10 09:03 AM
09/05/10 09:03 AM
moparx Offline
moparx  Offline
on my charger, it had a .050 shim. i upped it to .140[which is .090 added] that made a definate difference. since then, i have made a selection of different sizes of shims, and i will, at some point, add more and see what happens. i sent out a selection of shims to a couple of members for evaluation, but i haven't heard any results so far. for what it's worth, my car only has 18,900 original miles, so it's far from worn out, but i also had a power steering fluid/atf mix, which i have no idea what problems that mix could cause to the box or pump. as to the 1400# pressure, i'm "guessing" the pumps were tested from the factory for that #, and were shimmed accorgingly to arrive at that figure, as the 6 pumps i have done all had different amounts of shimpacks in them.
Re: Mopar Action article on power steering modification? [Re: moparx] #766548
09/08/10 01:53 AM
09/08/10 01:53 AM
CT: Corrupticut
Mr71Bee Offline
Mr71Bee  Offline
CT: Corrupticut
71bee with a fresh steer n gear set for level 1. I added .058 to the .060 shims in the pump. Felt a little better, but not dramatic.
For fun, I added another .050 to the mix. Not good. At slow speeds I would hit a point of no boost and it was very hard to steer. There was no difference at speed with this amount of shim.
I do not run a lot of caster, so this may effect the feel. BTW, this will be fixed soon with offset bushings. I put the PS shim pack back to the .060 plus .058 level.
Re: Mopar Action article on power steering modification? [Re: rutro] #766549
04/22/11 11:55 PM
04/22/11 11:55 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
What are all you loosey goosey guys running for caster in your front ends.
