Re: 440 stroker vs 451 stroker vs regular 440
[Re: torqueaddict]
#766451
08/05/10 10:09 PM
08/05/10 10:09 PM
Posts: 3,095 Idaho
Runner
Idaho
[Re: torqueaddict]
#766452
08/06/10 01:11 AM
08/06/10 01:11 AM
Posts: 43,368 Bend,OR USA
Cab_Burge
your goal is easily doable, shoot for 10.00 to 10.50 to 1 comp. ratio, cam should be in the 230 @ .050 to 250 @ .050, 108 or 110 lobe seperation angle ( I like the comp Cams XE275HL with power brakes or the XE 285HL grind with out power brakes. I have a 446 C.I. 440 block that has a set of ported "906" iron heads with bigger valves, same size valves as the stock Eddy RPM or Stealth heads have stock,TRW forged 6 pak pistons that make a true 9.46 to 1 comp. ratio That motor made 512 HP at 5500 RPM and 535 FT at 4000 RPM with a Edelbrock Performer RPM intake and a box stock Holley 950 HP on CA pump gas, it is for sell. I build motors for a living and race them to boot. That motor went 11:30 ET in my 3400 lb Duster spinning the tires at Woodburn several years ago, I made two runs on it and took it out. I have five motors and that is the littlest one ![](/ubbthreads/images/graemlins/image_294343.gif)
[Re: torqueaddict]
#766458
08/06/10 01:16 PM
08/06/10 01:16 PM
Posts: 16,934 NC
440Jim
NC
I currently have at the machine shop, I have a 440 block (it is a 78 casting year) and a set of stealth heads and a forged crank. I need to know can I get 500-600 fpt and 450-500 hp without stroking my motor
As much as I love the stroker combos available now-a-days, your application/desire will do just fine with a stock stroke 440. The only thing I will suggest is to buy some H-beam connecting rods. For around $400 they are a great upgrade and by the time you rebuild the factory rods with ARP bolts, resize the big end, magnaflux, etc. then the $400 rods aren't much more.
I have a stock stroke 440 with factory iron heads in my street '73 Cuda. Now my race engine is 4.250" stroke, 4.375" bore, 511 CID, 400 block, Indy 440-1 heads...
[Re: 440Jim]
#766459
08/06/10 08:52 PM
08/06/10 08:52 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
Like MrCab or 440Jim said new rods or ARP or some other good rod bolts. I had a 451(.060 over 440) TRW pistons stock rods and bolts,ported & polished 915 heads Comp Cams 286-750 roller. After about the 3rd pass shifting @ 6500 ,I had 1 good head and a few roller lifters left from a rod bolt breaking this was a few years back but I still remember it.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: gch]
#766461
08/08/10 12:53 AM
08/08/10 12:53 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I'm running a "440 inside a 383 block" it's got a 440 stroke, and the 383 is punched. 060 over, so the final displacement is 438" I'm also running a 440 length rod!
the 440 stroke and a 440 rod in the low deck gives a really short piston, and a very light rotating assembly. Fast revs! and lots of torque!
10.5:1 compression, OOTB eddy heads, and a comp XE275HL cam. RPM intake and a 750 holley HP double pumper, mechanical secondaries, and the motor made 535 tq and 505 hp on the engine dyno.
**Photobucket sucks**
[Re: torqueaddict]
#766464
08/09/10 10:39 AM
08/09/10 10:39 AM
Posts: 150 South Carolina, United States
carolinacuda
Your in the same boat as i was. I went ahead and did a budget build (kinda) with my 440. I stayed with stock stroke and went with .030 over trw 6pack pistons 2355's with a zero deck. My compression should be mid-10's. Had the rods checked and upgraded rod and main bolts of course. Its nothing exotic and i cant complain bout the power i've made with this motor. It has been thru several cams intakes, carbs, etc. I finally ended up with a solid cam (hughes), victor Int and Indy Ez's heads (stock port), 850 demon carb, a 3800 stall with 3.91 gears. All stock suspension. My car is a 74 cuda and i have ran 11.40's with it. I have no idea what the power / TQ is but it's enough to push my 3700 lb car to 11's. Although if i could rewind time i would have built it different and prob had more power and saved $$. I just wanted to let you know that you can make decent power with a basic 440. I know there is more in mine also. Its all bout a good combination of cam,heads,carb,gears,stall. IMHO ![](/ubbthreads/images/graemlins/beer.gif)
