Rear suspension help- need pics #766432
08/05/10 09:14 PM
08/05/10 09:14 PM
Anonymous OP
Anonymous OP
I am finally at the install point with the rear suspension and need a little help again. I have the ladder bars going right under the frame rails and was wondering were is the best place to mount the coil overs so some input and pics would be great if you guys wouldn't mind.
Robert.
Re: Rear suspension help- need pics [Re: ] #766433
08/05/10 10:15 PM
08/05/10 10:15 PM
MI
68shifter Offline
68shifter  Offline
MI
Your build looks like its coming along nicely. Through S&W, Bickel, and the Dave Morgan chassis book they all seem to want the shock as vertical as possible and the top angled 5-10deg back to allow for room. Most all the places sell upper shock mounts with three mounting locations and run a tube crossmember right above the mount. Heres a link to some stuff. http://www.swracecars.com/Files/pdf/10_300_400.pdf Hope it helps. Good luck
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
