Carb question for RB stroker racers Results are in!! #765941
08/05/10 09:27 AM
08/05/10 09:27 AM
New Jersey
Randy514 Offline OP
Randy514  Offline OP
New Jersey
First a little info on our current combo
1973 Cuda 3350 lbs RB 512 c.i. Pro-Comp raised port heads (just gasket matched) 727 solid roller 13.5-1 c.r. Team G intake Holley 950 HP carb (no spacer) Hooker comp headers 1-7/8 (I know too small) TF 727 Dynamic 9.5 converter flashes 5400 (footbrake) 410 Dana Cal-tracks Calvert 90/10 front CE 50/50 rears 10.5X28.5 MT slicks Shift at 6300 go through the traps aprox 6400 The car has been a [Email]10.43@130[/Email] 148 60ft
I know the 950 is a little on the small size for this combo My buddy lent us his 1250 Dominator w/adapter. (with the option to buy) We installed it yesterday jetted it down to 92s square and ran it in the shop. Naturally its not as responsive as the 950 due to the size difference but it revs freely without any bogs and idles clean It'll be a couple weeks before we can get to the track due to commitments and the hot weather. My question is this... In your opinion should we see a performance increase over the 950? Thanks Randy
Re: Carb question for RB stroker racers [Re: Randy514] #765942
08/05/10 11:08 AM
08/05/10 11:08 AM
tboomer Offline
tboomer  Offline
Randy...I am having a rough time with my 950 due to hot and humid conditions..What are you jetted at with the 950? Are you running PVs??
Re: Carb question for RB stroker racers [Re: tboomer] #765943
08/05/10 11:14 AM
08/05/10 11:14 AM
New Jersey
Randy514 Offline OP
Randy514  Offline OP
New Jersey
No power valves we jetted up 5 sizes when we took them out but jetted down to 85's when the hot weather came in mid 90's humidity was 70% 100 ft above sea level Plugs read good... Oh and the timing was locked at 35 Hope that helps...
Re: Carb question for RB stroker racers [Re: Randy514] #765944
08/05/10 11:19 AM
08/05/10 11:19 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
I run a 950 on my 499 in my Challenger and have tried a 1050 4500 a couple of times before. I have always ran slower with the 4500 but I have my 950 dialed in pretty well so you may experience something else.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Carb question for RB stroker racers [Re: Jacob Pitt] #765945
08/05/10 11:24 AM
08/05/10 11:24 AM
tboomer Offline
tboomer  Offline
I have no PVs...Went from 85s in my 950 down to 80s...I will race this weekend and see what happens...
Re: Carb question for RB stroker racers [Re: Randy514] #765946
08/05/10 11:25 AM
08/05/10 11:25 AM
WI
mopar873 Offline
mopar873  Offline
WI
Randy,
I am running a very similar combo. I have 440-1 heads, a comp .690 roller and 13.5:1. I am running a single plane Indy intake. My converter is flashing at about 5300rpm, I have 4.88 gears and I shift and go through the traps at 7200rpm.
My car is a mostly stock weight '65 Belvedere. The car had a 2" adapter with a 9375 Dominator on it last year. I installed a 1000cfm Holley HP with Barry Grant bowl extensions this spring. The car slowed down about 3 tenths to 10.7s spinning bad, but the low speed drivability and throttle response is way better. The plugs stay waaaaay cleaner for the limited street driving I do.
I have had good luck with 84 primary jets and 88 secondary jets with 34 degrees timing. Plugs look good.
Re: Carb question for RB stroker racers [Re: mopar873] #765947
08/05/10 11:25 AM
08/05/10 11:25 AM
WI
mopar873 Offline
mopar873  Offline
WI
BTW, factory PVs
Re: Carb question for RB stroker racers [Re: Randy514] #765948
08/06/10 02:04 PM
08/06/10 02:04 PM
NC
440Jim Offline
440Jim  Offline
NC
This is a tough question. Normally a race engine of that size will respond favorably to a Dominator carb. You are right the initial hit/response of the 4150 carb (950) will be better. However, in your combo, I feel too many other things are limiting the engine, so the Dominator will not ET better.
I would expect your combo to respond favorably to a carb spacer under the 950 carb. Have you tried that?
Re: Carb question for RB stroker racers [Re: 440Jim] #765949
08/06/10 02:48 PM
08/06/10 02:48 PM
New Jersey
Randy514 Offline OP
Randy514  Offline OP
New Jersey
Thanks for all the replies. Looks like we'll be able to T&T Sunday up Raceway Park. I'll take the 950 just in-case the Dominator is a bust.
My buddy gave me a one inch spacer.......what size would you suggest Jim? 2 inch? Hood clearance isn't and issue. Randy
