8.75 rear code 811 in paint on third member #765250
08/04/10 03:51 PM
08/04/10 03:51 PM
Overpriced Housing Central
RobX4406 Offline OP
RobX4406  Offline OP
Anybody know what that has for a gear set?
I think the axle housing has 810 on it in stenciled yellow paint as well.
It come from what I can remember a 68-70 Polara wagon
Re: 8.75 rear code 811 in paint on third member [Re: RobX4406] #765251
08/04/10 10:26 PM
08/04/10 10:26 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
Is that stenciled under the lower web on the side opposite the fill plug? If so, it is the assembly date. The ratio code is a series of square paint spots under the pinion. Usually in white. If it was a Sure-Grip, it will also have an orange spot with them near the mounting flange and one around the fill plug.
I used to have the chart, but I would have to look to see if I could find it. The stenciled date is usually easier to read than the ratio code.
Master, again and still
Re: 8.75 rear code 811 in paint on third member [Re: DaveRS23] #765252
08/04/10 11:22 PM
08/04/10 11:22 PM
RobX4406 Offline OP
RobX4406  Offline OP
IIRC it was opposite the fill plug
A friend had this pulled and asked, I was too lazy to check it by hand.
If I can get the other info I;ll post it.
