cuda power brake pedal return spring #764827
08/03/10 09:45 PM
08/03/10 09:45 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
might anyone have a picture of a power brake pedal return spring? i have a 1971 cuda 4 speed with power brakes and the spring im using is not the correct one. its not lifting the pedal. thank you
Re: cuda power brake pedal return spring [Re: kingkt] #764828
08/03/10 10:32 PM
08/03/10 10:32 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
As far as I know the brake pedal does not have a return spring. You've got something else wrong there.
Re: cuda power brake pedal return spring [Re: kingkt] #764829
08/03/10 10:37 PM
08/03/10 10:37 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Again,..........E body 4 spd, brake spring location #19
Re: cuda power brake pedal return spring [Re: DAYCLONA] #764830
08/03/10 10:46 PM
08/03/10 10:46 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
thanx again. the problem im having is knowing what the actual spring looks like. i found a spring in the pile of parts i have that fits but it is really not returning the pedal. i think i have the wrong spring.
