Re: tunning a 383, HELP
[Re: Mr.Yuck]
#76472
06/20/08 06:52 PM
06/20/08 06:52 PM
RapidRobert
I would set the total w vac adv disconnected at ~36-38 & see where the initial falls at at that point as you always need a fair amount of initial because of a hotter cam always wants more advance depending on the particular cam..all in by 2k is pretty fast & the most important thing is to keep it from pinging no matter what & to ans your q you pretty much want as much adv as you can without it pinging at ANY point in time.When you have that where you want it then hookup your vac adv which can put your total in the 50's under light throttle & it too can be adjusted with a 3/32" allen wrench for the most adv short of pinging under part throttle/cruising(where vac & therefore vac advance)is highest.
