Building a 440 6 pack motor from a 440 non HP #76414
06/20/08 10:24 AM
06/20/08 10:24 AM
West coast
71Beelover Offline OP
West coast
I'm looking at picking up a 71 6-pack car that is missing its motor but I have a 70 440 non HP with a forged crank that im thinking of using to build the replacement motor. I not that knowledgeable about the 6-pack motor besides the obvious 6-pack set up so I have a few questions
Am I right in the fact that all 440 motors have the same block? What all do I need to make this a correct factory looking 6-pack motor besides the 6-pack set-up....What heads, rods, exhaust manifolds, crank balancer, fan...etc?
Re: Building a 440 6 pack motor from a 440 non HP [Re: 71Beelover] #76415
06/20/08 10:41 AM
06/20/08 10:41 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
anything inside is on you. If you are going from scratch you might as well go get new crank/rods/pistons and so on. You can find kits as low as $1399. If you have a crank just call summit or jegs and order a engine kit. I would not use 6-pack rods or have old LY's re-coned. There are nicer, lighter stronger rods availble. As for externals I'm gussing you just want to make sure all the dates/part number would be available on a 71 model.
Re: Building a 440 6 pack motor from a 440 non HP [Re: 71Beelover] #76416
06/20/08 10:41 AM
06/20/08 10:41 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
You would need the big rods and external balanced type harm. balancer and torque converter or flywheel for one. The block should also be stamped HP on pad too I believe for 1971 too.
Re: Building a 440 6 pack motor from a 440 non HP [Re: buildanother] #76417
06/20/08 01:36 PM
06/20/08 01:36 PM
Alabama
BigMoneyLewis Offline
Alabama
In my opinion , If you are building a real 71 V code car, you should look for a correct dated 71 HP block . All 71 440 HPs have the six pack rods crank balancer , so that is a much better,and correct, starting point for your build.
Greg
Wards Classic Car Radio Repair Specializing in restoration and sales of Mopar A B E body radios
We can restore YOUR radio usually in less than 7 days
Visit our NEW website..
http://www.wardsclassiccarradiorepair.com
gregward@mchsi.com
phone 256-852-0955
