518 endplay, .085 to loose
#763417
08/02/10 12:54 PM
08/02/10 12:54 PM
Posts: 6,816 Alton, IL
Dakota_Don
Alton, IL
I checked my endplay and id like to tighten it up a bit.. I did get a new thrust-waser kit with the parts, i did have to use a re-man pump, and new 5 gear planatary set, all of the old washers were burnt and scortched (massive endplay before it came apart) Anyway i installed the new washers that were the closest in thickness to the old one.. Well I ended up using the thickes washers between the drums, input and output shaft, and the front pump washer.. and with out the pump gasket i have .085 total. The astg shows .022 to .091 Id love to get it down another .020 can I use two thinner washers that have a total thickness thats .020 thicker then the washer jIhave in there now behind the pump? or will that be to much friction?
Don
