Re: anyone running electric vaccum pump for power brakes?
[Re: magnum440]
#763072
08/02/10 08:32 AM
08/02/10 08:32 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
My 493" only pulls 5-6hg at idle, but the power brake booster seems to work just fine? It is a stick car, and I did just have the booster rebuilt. I'm not sure at what minimum vacumm rating that the booster problems start at, but maybe I lucked out and am just above that?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: magnum440]
#763073
08/02/10 10:31 AM
08/02/10 10:31 AM
Posts: 236 Maryland
cudaboone
Maryland
Yes, i run one on my 528 hemi. It's great. Only runs a few seconds when you turn on the key. I have never heard it run with the motor running. I don't know how you could hear it with the car running because it does not make that much noise. Mounted it in the fender well just opposite the booster and it is hardly noticeable.
[Re: jbc426]
#763076
08/02/10 09:17 PM
08/02/10 09:17 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Your only running a single diaphram booster,(from your pic) the requirement is less,...if you were running a double diaphram (Bendix) there would be problems,...an automatic transmission compounds the problem,....a manual tranny, you step on the clutch just prior to braking, so engine RPM isn't allowed to drop drastically, like it would with an automatic will brakeing,...so there's more vacumm present with a manual tranny equipped car just prior to braking
[Re: magnum440]
#763078
08/05/10 10:51 PM
08/05/10 10:51 PM
Posts: 70,126 Here
DirectSubjection
Tacohead. The First and Only
Here
I put one of the GM ones on my 66 Toronado plumbed right in to run the brakes - worked great and never knew it was there sound-wise.
Ride eternal, shiny and chrome
[Re: DirectSubjection]
#763079
08/06/10 08:14 AM
08/06/10 08:14 AM
Posts: 5,911 Athens, Greece
Pyper70
Athens, Greece
I have an electric pump out of a 78 Cadillac DeVille. I actually popped three of them out and made one unit with the newest parts of the lot. I have it mounted under my battery tray, completely out of sight, on rubber feet. You can hear it when it turn on when I put the key right before turning over the starter. I let it run for the 3 seconds and then kick over the motor. I have it hooked up to a Vacuum canister that looks like it holds about a liter of space. Its mounted in the fenderwell. When we first fired up the motor the vacuum gauge was at 11". These days its at 5-6 because I was tweaking the engine here and there. With a few diagnostic tools I just picked up I am going to do my best to get her back up to 11" or more. I had to install it because I have the factory brake booster, and vacuum headlights. Ever seen a 69 Charger with the one headlight opening quick and the passenger side sloooooooooooooooowly opening...yeah..that annoyed me...Don't have a lopey cam, just a 480/280 Isky. I have a 540 roller cam set up in the next motor so this pump will come in handy then.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
