idler pully #762907
08/01/10 03:33 PM
08/01/10 03:33 PM
ca, slo.
P
paulyvault Offline OP
P
ca, slo.
hey guys i have a squeeeeling noise out of my 69 charger 383 at about 2500+ RPMs all my belts line up so i figured it might be the idler pully. how do you change one? there is no nut for it its just on a bracket? not sure how to take it off and put a new one on? any help would be great.
Re: idler pully [Re: paulyvault] #762908
08/01/10 03:52 PM
08/01/10 03:52 PM
I'd VERY CAREFULLY lube each side (each side side not top/bottom) of each belt at idle w a bar of gold dial soap & see if it's a belt prob. If indeed the idler pulley might have to R&R the whole assy to get some grease in there.
