cuda sway bar links #762786
08/01/10 12:05 PM
08/01/10 12:05 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
does anyone know if there is a difference between the front and rear sway bar links?
Re: cuda sway bar links [Re: kingkt] #762787
08/01/10 12:24 PM
08/01/10 12:24 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
rears look totally different factory wise...aftermarkets might look the same...
Re: cuda sway bar links [Re: kingkt] #762788
08/01/10 12:26 PM
08/01/10 12:26 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
I believe that there is a sixe differance and I dont think that the rears are longer than the front.
Re: cuda sway bar links [Re: kingkt] #762789
08/01/10 06:33 PM
08/01/10 06:33 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Fronts - 1970 and later use a thru bolt style and with a center tube type spacer
Rear E-body bar use's the 1969 and older A/B body style link with a threaded stud on each end and no center spacer
Close up of the rear link only with no bushings on it
