Re: 727 wont shift to third
[Re: REDNICK]
#762426
08/01/10 04:57 PM
08/01/10 04:57 PM
Posts: 25,796 Rio Linda, CA
John_Kunkel
Rio Linda, CA
No 3rd gear right after an overhaul is often the result of the builder leaving the 11/32" check ball out of the valve body.
Is Reverse OK?
[Re: John_Kunkel]
#762428
03/05/11 05:45 AM
03/05/11 05:45 AM
Posts: 345 Ohio
DGE470
Ohio
Is Reverse OK?
A long time ago a friend and myself put a shift kit in a 727 and the instructions said to remove the check balls from the valve body,then it said which ones to leave out and which ones to put back in...except for one,so we picked leave it out.We put it all back together and took it for a test drive and it didn't have 3rd gear.So we took it back apart and installed the check ball that we had left out,and it worked fine.The worst part was by the time we had finished it was dark,24 degrees,windy,and snowing,and we did it outside.
