Amp gauge electrical question
#762165
07/31/10 03:13 PM
07/31/10 03:13 PM
Posts: 583 Raleigh, NC
rockerbob
Raleigh, NC
Want to eliminate the amp gauge in my bracket car (69 Satellite) & install a volt gauge. Can I just simply unhook the wire at the stock amp gauge & splice them together or do I have to do something else?
2005 Dakota 4X4 3.7
2004 Rumble Bee 5.7
1978 Diplomat 318
1969 Satellite 318 "bracket racer"
1966 Barracuda (in progress )
1964 Dodge 330 (future race project)
1962 Belvedere (HUM????)
Re: Amp gauge electrical question
[Re: rockerbob]
#762171
07/31/10 06:10 PM
07/31/10 06:10 PM
rockerbob
Raleigh, NC
Well I unhooked the wires at the back of the amp gauge & connected them together. Everythink still works (except the amp gauge ofcourse) I am getting 14.5 volts at the alternator. 13.5 athte trunk mounted battery at idle. When I rev it up the amp gauge would peg, but the voltage at the battery world DROP to 12.5 ? So I figured the amp gauge was bad. Didn't fix my problem. Still not charging at the battery when reved up. I'm not good at electrical stuff & I'm getting in over my head....I know this stuff is easy to many people, but I just cant grasp it. Any help or ideas? Maybe I should run a new wire from the gauge to the battery?
2005 Dakota 4X4 3.7
2004 Rumble Bee 5.7
1978 Diplomat 318
[Re: tubtar]
#762175
07/31/10 06:53 PM
07/31/10 06:53 PM
Posts: 146 michigan
tonycpe
michigan
sometimes , when the brushes in the alternator get worn , they will bounce at high rpm.
Old Fogey Racing Ltd.
[Re: Sixpak]
#762178
07/31/10 09:09 PM
07/31/10 09:09 PM
rockerbob
Raleigh, NC
Ok - does the heavy black from the alternator still go through the bulkhead at the firewall? That is a potential problem, as well as the heavy red from the battery. Either or both can corrode from moisture causing resistance which can actually burn/melt either wire. Pull both plugs and look. If they are usable, wire brush and grease the connectors and try it again. Also scrape the female connectors with a paper clip or fine jewelers screwdriver in the bulkhead they mate to. The heavy red supplies juice to the car when the motor isn't turning the alternator to make juice, like when you start the vehicle. Once the car is running, the alternator pushes juice thru the black and back thru the heavy red to charge the battery, and power all of the circuits in the car.
One fix I've done is to totally bypass the connectors in the harness; drill two holes, use two grommets and run the heavy red and black thru them and not the bulkhead connectors.
The other thing ya got to be sure of is that the volt regulator has a real good ground, as does the negative of the battery. There should be some sort of washer or Sems bolt with a toothed washer that cuts into the sheet metal for either.
Yes the wiring from the alternator is all still stock & go's through the bulkhead. I did check my grounds & the ground in the trunk to the frame (trunk mounted battery) is a tad warm? Its tight & clean. I will double check the VR, but I tried 3 different new ones I have & no change. Kinda hard to believe they all didn't ground. Anyhow thanks....got some things to check I suppose. Concerned about that warm ground. Could that be a problem?
2005 Dakota 4X4 3.7
2004 Rumble Bee 5.7
1978 Diplomat 318
