Valve spring compressors? #76200
06/19/08 10:18 PM
06/19/08 10:18 PM
Townsville
3
3_wheelie Offline OP
Townsville
Just wondering what kind of valve spring compressors you guys have had good experiences with/recommend .
I picked up one of the C-clamp style ones from summit today and all that came of it was a big bent valve spring compressor and all my valves are still firmly in place. These heads are off the engine also.
YutKillYut Grozny lives!
Re: Valve spring compressors? [Re: 3_wheelie] #76201
06/19/08 10:28 PM
06/19/08 10:28 PM
NH
Fastback67 Offline
Fastback67  Offline
NH
Don't give up...I had a Sears job that did the same thing with old "set in there ways" springs, locks and keepers. Found that I had to put the clamp on... apply one or two clicks of pressure... then hit the old lock & keeper assembly with a socket and a mallet to break it free... after that it would work great! It simply didn't have the power to break them free on it's own without bending all to he**, but other than that, it worked great for $19... and it worked just fine on brand new stuff. It just didn't like heads that had been in use for the last 20 years... they were locked on too good.
Re: Valve spring compressors? [Re: Fastback67] #76202
06/19/08 10:42 PM
06/19/08 10:42 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Yes, you have to rap the edges of the retainer with a hammer (or socket, just not TOO hard) to break the keys loose from the retainer. If you don't do that first, the compressor will do nothing. Been there, done that. If you rap it too hard, the keys will fall off and the spring and retainer will hit you in the face, not good, use caution.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Valve spring compressors? [Re: GO_Fish] #76203
06/19/08 11:26 PM
06/19/08 11:26 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
The ones like this style are a joy to work with compared to the rest.
http://www.compperformancegroupstores.co...ode=VALVESPRING
Re: Valve spring compressors? [Re: Neil] #76204
06/20/08 06:27 AM
06/20/08 06:27 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I have the type like you bought.They work ok for light springs.My kid bought the type that bolts to the hold downs.Had his BB springs changed in the car in an hour.Mancini and Summit has them.I believe Mancini is cheaper.Rocky
Chrysler Firepower
Re: Valve spring compressors? [Re: GO_Fish] #76205
06/20/08 08:20 AM
06/20/08 08:20 AM
NH
Fastback67 Offline
Fastback67  Offline
NH
Yup, that's why you put the clamp on it first and apply a small amount of pressure. The extra force of the clamp on the spring means you only have to tap them, and the assembly will be firmly held in place.
