What's needed to change to Sanden from stock pump. #761655
07/30/10 06:50 PM
07/30/10 06:50 PM
Dallas, Wisconsin
BurntOrange Offline OP
Dallas, Wisconsin
My Dad needs a new AC compressor. '69 Fury 318.
Which Sanden compressor?
Brackets?
Fittings?
Anything else?
Where to get what we need?
Thanks for looking!
Re: What's needed to change to Sanden from stock pump. [Re: BurntOrange] #761656
07/30/10 08:48 PM
07/30/10 08:48 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Classic auto air
Bouchlin performance
Are 2 I know of. Goggle them and call them. They can answer all your questions.
Cost me about 1200 bucks in parts for under the hood to convert to a sanden/R134 I used all the stock interior stuff.
I did all the labor, $1200 was parts.
Re: What's needed to change to Sanden from stock pump. [Re: BurntOrange] #761657
07/30/10 09:18 PM
07/30/10 09:18 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
When changing from the original compressor you need a device to cycle the clutch for evaporator temperature control, early Mopars used a valve in the compressor to control evaporator temperature.
Re: What's needed to change to Sanden from stock pump. [Re: BurntOrange] #761658
07/30/10 10:06 PM
07/30/10 10:06 PM
Bucks County, PA
500Stroker Offline
500Stroker  Offline
Bucks County, PA
I bought the compressor upgrade kit from Classic Auto Air years ago for $499. Included everything I needed.
http://www.classicautoair.com/MOPAR_OEM_Parts_Compressor.html
