fired it up this morning.
Ran it for about 10 mins at 2k ran up to about 230 temp then shut it off and let the water pump and fan run for about 5 mins to bring it down. then fire it up and ran it for another 10 mins at 2k.
My wide band was reading 12.5 on both sides at 2k
I can't belive how quiet this motor is to the last one
I have one small oil leak looks like it's coming from the back of the pan cleaned it up and snugged the bolt up. gonna run it again after I put the inner valve spings back in next weekend. See if it still leaks
then drain the oil and put new oil in and cut the filter apart
