Re: TKO 600 68-70 B body Install Tunnel mods?
[Re: roadrunner7020]
#761145
07/30/10 09:55 PM
07/30/10 09:55 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Tony, After installing quite a few Keisler transmissions for myself and customers,...I'll give you my on the 70 Charger install, as I have performed that as well,.....purchase a repro 4 spd hump, forego the sheetmetal peice supplied in your kit, cut the floor open for the "factory" repro 4 spd hump, don't install it yet....mock up the install by installing the bell, and transmission, along with the supplied tranny crossmember,....check your installed transmission angle, the tranny tailshaft should be pointing downward,.....useing an inclination meter, measure the rear pinion angle,...the pinion will point upward(note if your performing this with the rear suspension hanging, the pinion angle changes,...measure with the car on the ground, sitting on it's wheels, or sitting on a 4 post drive-on ramp),...you want to have the transmission and pinion on equal paralell angles of one another,...example 5 degrees - on the tranny, and 5 degrees + on the pinion,....measure the rear pinion, factory is usually 3-5 degrees +,....unless you've modified your rear end perches/springs/etc,....you need to determine that the engine/transmission driveline angle is exactly what you want, you may need to shim the tranny mount to acheive the angle needed, and in most cases, with the Keisler, it's upward, which means more tunnel mods to get the tranny into the hump,....don't be afraid of cutting the floor, your going to put a carpet and/or console over it,...so why fuss?,....driveline correctness and operation are more paramount,...last thing you need is vibrations from a poorly set-up driveline,.....the Keisler aluminum case Tremec runs hot in OD mode on extended runs, so the more room you have around the tranny for airflow the better,...use some dynamat on the floor for heat barrior after you've determined the floor mods,...with the tranny mocked up, and the 4 spd hole cut out in the floor open, it gives you a better idea of any interference you need to address,....then fit the "factory" 4 spd hump, there's plenty of clearance around the hump, but you'll need to weld up the hole were the original shifter would mount, as the Keisler shift tower is located approx 3" to the center of the factory hole,...the supplied Keisler shifter offset will center the shifter in the factory console, or under the shifter boot, should you desire no console,...the factory 4spd shifter has a 3" offset as well, just in the other direction to center the shifter, so don't worry about the location, it will be correct with the Keisler,....but do follow the instructions supplied from Keisler, if you don't understand something call Keisler,....if you wish to PM me here at Moparts, I can answer most if not all your questions regarding your install,....trust me after you've installed your Keisler TKO, correctly, it'll be the only transmission you'll prefere to have in a car Here's a driveline pic to help you out, regarding driveline correctness,...you don't need the driveshaft to determine your tranny and pinion angles, Mike
[Re: NV69B7RR]
#761146
07/30/10 10:02 PM
07/30/10 10:02 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Tony,...here's a pic of my interior, I'm running the Keisler TKO 600/650 5 spd .64 OD,...factory console in the stock location, factory shifter boots, with a Keisler TKO repro console 70 pistolgrip shifter,...I'm also running the Keisler hydraulic throw out bearing set up,...which set up are you running
I have about 6 years and 40K+ miles on this unit,...hard miles, street/highway/PowerTours/road courses/tracks...only problem in that time was a blown hyd. throw out bearing, nothing major,....but I am running a somewhat non-recommended HD clutch set up behind my Keisler
Mike
#761148
08/01/10 05:24 PM
08/01/10 05:24 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I know you said that there was an issue with your bearing but i also believe they have changed setups since You also mentioned a heat issue in OD what are you calling extended periods of time
Tony, ...the problem I had with the TObearing was it basically gernaded,....I had 5 yrs of hard miles on it too, about close to 40K street and tracks,.....the bearing itself was OK, just the hyd sleeve let go,....but then again it was right after speed shifting thru 4 gears during a heavy launch,....plus running a Sachs BorgBeck style 3 finger 2800 lb clutch and Kelvar disk isn't recommended by Keisler,...as they usually run the diaphram type cover/clutch set-ups.....but it was an easy fix in just under 2-3 hrs when the parts showed up,....at that time, I also upgraded to the Keisler modified Wilwood master,...as I had been running the FEP master, the Wilwood was a much needed upgrade
As far as the heat generated in the passenger compartment, it's very noticeable, at times it feels like you could fry an egg inside the console ,....so spend the money on some good dynamat, or something good that will barrier the heat,...avoid any adhesives or adhesive mats, as they will melt/stink when heated
Mike
[Re: DAYCLONA]
#761149
08/02/10 01:40 PM
08/02/10 01:40 PM
Posts: 4,064 Boca Raton, Florida
jpilone
Boca Raton, Florida
I finished putting mine in a few weeks ago, was a major PITA to cut and get right, take your time, and making the keisler supplied sheetmetal is fine, but it takes patience to bend the metal to fit the tunnel. the cut-out template they give you is fine, but you'll need to install and check clearance. I had to "clearance" my floor a bit to ensure the trans didn't hit the floor.
-Jarrod Pilone '70 Plymouth RR Convertible with amazing custom paint(Tribute/Recreation/Whateveryouwannacallit) My Project Thread
[Re: jpilone]
#761150
08/02/10 01:41 PM
08/02/10 01:41 PM
jpilone
Boca Raton, Florida
Here's the after, before I used the seam sealer
[Re: jpilone]
#761151
08/02/10 09:48 PM
08/02/10 09:48 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Nice job Jarrod ,....I usually recommend installing the factory 4 spd hump for several reasons when converting an automatic car rather than use the Keisler patch,...1, more room the merrier, esp when you need to remove the tranny for a clutch job,...2, air circulation,...you'll find out how hot! that tranny gets on long cruises in OD,..3, your installing a manual tranny, why not make the floor look factory,...4 if you order a manual carpet set, what are you going to do with all that extra mat'l? thats allowed for the factory hump?,....an automatic carpet will fit, but the increased hump using the Keisler patch will leave you short when it comes to the door jambs, depending on the manufactures carpet,...points to consider
[Re: boydsdodge]
#761153
01/22/11 04:40 PM
01/22/11 04:40 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I know the post is kinda old but I have to ask. Can there be a cooler installed on a TKO600? You would need a pump of some sort through to a cooling rad, or I guess I could run ducted scoop like on brake system cooling. Has anyone tried?
Jackson, as I stated earlier about the OD generating some HEAT,....if your going to be running the car for long periods of time in the OD mode (several hrs), at speed (triple digits, or close too) the Keisler box will put off some serious heat, that's why I recommended some Dynamat before carpet install,...you could rig a cooler, but as you said, you'll need a pump,preferbally electric, an electric fuel pump could be utilized, as the GM's syncromesh fluids viscosity is rather light, and there's plenty of plugs on the case, I'd recommend either braided stainless hoses for the plumbimg, or pipe it hard with stainless or steel tube, plenty of coolers on the market,...I WOULD NOT use the tranny cooler in an auto radiator,...keep it seperate
Mike
