How to ID 18 spline A833 4 speed?
#760610
07/29/10 03:44 AM
07/29/10 03:44 AM
Posts: 726 California
BigDaddy440
California
I'm going to look at a 4 speed trans which the seller is telling is a 18 spline "hemi" trans.
I'm assuming the input-shaft has 18 splines and has a larger diameter than a standard trans? Correct?
What should I be looking out for here? I'm wanting the trans for an A12 Roadrunner, and I don't want to get "taken" by buying a non-correct trans.
Did these 18 splines come in other vehicles other than hemi and sixpack cars? Trucks maybe? Is there a diff between various 18 spline trannys?
thanks!
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
Re: How to ID 18 spline A833 4 speed?
[Re: BigDaddy440]
#760611
07/29/10 05:27 AM
07/29/10 05:27 AM
Posts: 428 Mid-Atlantic
Scatransit
Mid-Atlantic
If there is a full VIN stamp on the side, that would help...If it begins with a "WS" (Coronet R/T) or "RS" (GTX), or if the engine code is a "J" (Hemi), then it would be an original 18-spline b-body unit.
[oo]======[oo]
[Re: Scatransit]
#760612
07/29/10 07:35 AM
07/29/10 07:35 AM
Posts: 4,285 Ohio
64dodge572
Ohio
If your looking to buy it for the 69 car, bearing retainer casting should be c97621 and the tail housing casting should be c99128 or c99621. I would be more concerned with the condition of the inside, thats the expensive part to rebuild if it has been abused. Dan
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: Stanton]
#760615
07/29/10 09:53 AM
07/29/10 09:53 AM
Posts: 18,688 Fresno, CA
Jim_Lusk
Fresno, CA
An 18 spline is an 18 spline - period. There will be 18 splines on the input shaft. They only used a 308 bearing so even if the front retainer is wrong or missing it can be replaced with the correct one.
NOPE. The very early 18-splines used the 307 bearing. I believe every one of those does NOT have the stamp pad on the side, either.
The last one I sold was an early unit and was missing the bearing retainer, but did have the correct early bellhousing. The trans was in excellent condition and I got $750 for it (I'm guessing '03-05 for a time frame). I figured that half of what Passon wanted for a new one was fair and it was the first thing I sold at Spring Fling that year for full asking price.
Inspect it carefully and expect to do a full rebuild.
[Re: Jim_Lusk]
#760616
07/29/10 11:33 AM
07/29/10 11:33 AM
Posts: 75,369 A gulag near you.
JohnRR
A gulag near you.
, what he said plus a 71 up 18 spline trans has a different gear ratio, it's a 2.47 first gear instead of 2.65 (2.66??)
[Re: BigDaddy440]
#760617
07/29/10 01:41 PM
07/29/10 01:41 PM
BigDaddy440
California
Thank you everyone, very good info here. The guy who's selling the trans SAYS the internals are in great shape, but we'll see. I've never ID'd an A833, so other than counting the splines, I had no idea what to look for.
I'll keep you all posted. Going to see it tomorrow. I'm hoping to pay $500, but we'll see how it looks. I'll have it gone through regardless. He says he had the bell housing and a factory shifter too.
Thanks again! -dan
[Re: JohnRR]
#760619
07/30/10 08:21 AM
07/30/10 08:21 AM
Posts: 2,172 Ohio
theclutcher
Ohio
23 spline had 2.66 or 2.47 18 spline had 2.65 or 2.44
[Re: theclutcher]
#760620
07/30/10 08:50 AM
07/30/10 08:50 AM
JohnRR
A gulag near you.
thanks for that correction
