518 front clutch clearance?updated is this ok
#760503
07/28/10 10:40 PM
07/28/10 10:40 PM
Posts: 6,816 Alton, IL
Dakota_Don
Alton, IL
hello, i am working on this 518 trans, the book says the clearance for a 4 clutch disc should be .067 to .134, is this correct, for one this pack in this unit only has 3 clutches in it, there are 4, thinner clutches that went into the rear(fwd)drum? I did notice the steels are thinner then to old ones, but they are burnt. I have .120 for the front clutch pack w/3 clutch disc (thicker disc)
does this seem ok,
thanks
oh i have .026 on the fwd/rear drum
