Holley blue pump
#760445
07/28/10 09:55 PM
07/28/10 09:55 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
I'm getting ready to swap out either for another one or a different one. Just curious to see people's opinion on blue pumps and other brands. This is just for a street/strip 64 Valiant. 346 with six barrel set up. Ported E-brock heads with only around 9.5 to 1 compression.
The problem is that it went quite....hardly doing anything. I haven't really got too knee deep into to yet. I was thinking of just going ahead and buying another Holley blue pump and then rebuilding the one that's on there for a spare.
Thanks for the feed back.
Moparlee
Re: Holley blue pump
[Re: Robbins]
#760446
07/28/10 10:06 PM
07/28/10 10:06 PM
Posts: 7,506 Az
Crizila
Az
I haven't had much success with vane pumps for fuel - and won't buy another one - any brand. I currently run a Holley geroter pump ( 150 gph ) with no problems for 3 years now.
Fastest 300
[Re: Alikazam]
#760450
07/30/10 09:49 PM
07/30/10 09:49 PM
Robbins
Joplin, MO USA
Thanks guys. I already have an electric blue pump an I really don't want to change the fuel system to much from what I got as far as pluming and such.
Thanks guys.
Moparlee
Re: 383man
[Re: 383man]
#760453
07/31/10 06:56 AM
07/31/10 06:56 AM
Robbins
Joplin, MO USA
So have has anybody had to trouble shoot one? Like when they decide to go quite? Has anybody put a kit in one and it worked? Thanks again everybody for you help.
Moparlee
[Re: Robbins]
#760454
07/31/10 07:43 AM
07/31/10 07:43 AM
Robbins
Joplin, MO USA
Another question.....has anyone put in a shut off valve so that they could work on the system back at the tank? If so what and where did you get it, if you don't mind me asking? Thanks again for your time.
Moparlee
[Re: Robbins]
#760457
07/31/10 08:35 AM
07/31/10 08:35 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
I always have a ball valve at at the sump so that I can shut off the fuel supply when the engine is not running. It is before teh filter and pump so that I don't have to drain the cell/tank to replace the filter or pump. Or worry about fuel siphoning while the car sits. It doesn't happen often but have seen it.
[Re: MoparforLife]
#760458
07/31/10 09:46 AM
07/31/10 09:46 AM
Challenger 1
Cincinnati, Ohio
Sorry, but that filter is so wrong if you that in front of the pump, Real bad example. #10 should be feeding the pump, no smaller.
[Re: Robbins]
#760459
07/31/10 12:18 PM
07/31/10 12:18 PM
Posts: 1,996 s. e. pa.
calrobb2000
s. e. pa.
hi got a blue holley on my car , have had it appart several times due to dirt in tank ,had to clean screen in pump . worst thing is noise , get a carter 4594 much quieter and efficent pump for a street car . and for a street car a filter in front of the pump is not a bad thing !
[Re: Robbins]
#760461
07/31/10 03:00 PM
07/31/10 03:00 PM
MoparforLife
Upper Midwest
I always have a ball valve at at the sump so that I can shut off the fuel supply when the engine is not running. It is before the filter and pump so that I don't have to drain the cell/tank to replace the filter or pump. Or worry about fuel siphoning while the car sits. It doesn't happen often but have seen it.
Cool, that's what I need right there......I'm in to ease of maintenance.
Don't know what is so wrong about it. It has fed the car that way for years and works fine. The ball valve is between the cell and the filter , this filter is before the pump as it is supposed to be. Have had guys that have race for a lot of years tell what a good idea that that is and have installed one. So it can't be too wrong. You can feed your pump with as big a line as you want to run to it but it isn't going to feed any better or faster than the fitting & inlet size of the pump.
[Re: Challenger 1]
#760463
07/31/10 04:49 PM
07/31/10 04:49 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I have a blue Holley pump with a Fram HP-1 filter in front of it.It's been run that way since 1981,and I changed the pump in 2000 because the fuel cell was left dry for a year and the foam went thru the pump.The current pump has been running for 10 years with no problems.
