What starter& flywheel with a Keisler 5 speed &Hemi ?? #759695
07/27/10 08:57 PM
07/27/10 08:57 PM
Steeler Country
scottydog Offline OP
Steeler Country
Getting a 5 speed setup and needing to know which flywheel to find at the Nats. Heavy streetcar. 650 hp. Also, will my mini starter work, or do I need the RobMcc unit? Thanks, Scotty
I mostly enjoy golfing in the 70's.. The eighties are just too hot, and 60's I usually get chilly !!
Re: What starter& flywheel with a Keisler 5 speed &Hemi ?? [Re: scottydog] #759696
07/27/10 09:02 PM
07/27/10 09:02 PM
IN
ahy Offline
ahy  Offline
IN
A standard flywheel that matches your crank will work. For a street car I'd look for a standard weight (+/- 30#) steel flywheel. A mini starter that worked before should still work. I'm running the MP mini. I don't believe the Keisler changes starter fit... more a matter of headers and block clearance.
