Where to buy??? Mopar 1970-72 dana 60 pinion snubber #759413
07/27/10 01:26 PM
07/27/10 01:26 PM
Bel Air Maryland USA 21014
wmwalden Offline OP
wmwalden  Offline OP
I need to buy one of these.
Does anyone know where and how much?
Bill
or should I get an adjustable one?
I do race some.
Re: Where to buy??? Mopar 1970-72 dana 60 pinion snubber [Re: wmwalden] #759414
07/27/10 02:09 PM
07/27/10 02:09 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
No where have I read that anyone is successfully using one of these. They are old school. If you need more traction investigate a set of Cal-tracks, and or putting more stickier rubber on.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Where to buy??? Mopar 1970-72 dana 60 pinion snubber [Re: HemiRick] #759415
07/28/10 12:32 PM
07/28/10 12:32 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
if you dont want to modify your suspension(ss-springs)get an oem one,i just got an adjustible for my 8-3/4" and in its lowest setting its sky high,i dont think i can even get it in.its the modell with a pin going through it.ive read that others have had problems with them being so tall to, and that maybe the newer screw-down modell might be able to set lower.
Re: Where to buy??? Mopar 1970-72 dana 60 pinion snubber [Re: wmwalden] #759416
07/28/10 04:20 PM
07/28/10 04:20 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
They do help if your springs are wimpy or marginal, to keep the axle from rotating too much while running sticky tires or slicks.
Re: Where to buy??? Mopar 1970-72 dana 60 pinion snubber [Re: buildanother] #759417
07/28/10 10:56 PM
07/28/10 10:56 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
We have them in stock and ready to ship. Here you go:
http://www.pepsparts.com/proddetail.asp?prod=7072d60ps
Nobody gets in to see the wizard!
Ain`t no way!
Ain`t no how!
