What should I expect? Nitrous gurus... #758768
07/26/10 09:05 PM
07/26/10 09:05 PM
Charlotte NC
cudadave72 Offline OP
Charlotte NC
My Cuda currently has run a best of 11.38 @ 117 mph. Coming up I am swapping my internals into a Resto block so that I can use a power adder without destroying the stock block. Based on my current time what would I expect to run on a 225-250 shot of nitrous assuming I hook and all goes well. Car is 3800 with me in it.
Re: What should I expect? [Re: cudadave72] #758769
07/26/10 11:04 PM
07/26/10 11:04 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Im NO expert but if EVERYTHING is working correctly,I would think you should be able to gain a full second if not a little more. I know of guys that run mid to low 12's on motor and with a 175-200 shot run mid 10's.
Re: What should I expect? [Re: cudadave72] #758770
07/27/10 05:14 AM
07/27/10 05:14 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Well if you just blast a 250 shot with the way the engine sits it won't pick up as much if you tighten your converter up / better matched cam (wider centerline) etc.. looser ring gap! Your 11.38 is gonna slow down with a tighter converter also! Good luck Dave
Also maybe you should re title the thread to get some of the big nitrous guys to set you up!
Mopar Performance
Re: What should I expect? [Re: moparniac] #758771
07/27/10 05:17 AM
07/27/10 05:17 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Also I think 4404dart on here goes 10.5 on motor and 8.8x with a 250 shot ... Maybe 300 can't remember but I'm pretty sure he is setup for big hits ... Maybe he will chime in !!!
Mopar Performance
Re: What should I expect? [Re: cudadave72] #758772
07/27/10 08:38 AM
07/27/10 08:38 AM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
As stated, your car ET's very well for the MPH, so you're going to have to go to a tighter converter......
I know a local guy that's got a Mustang set up for nitrous (tight converter and cam) that runs 11.30's on nuts and on his first pass with a clean, REAL 200 shot, ran 9.70's....
So, I'd guess your car with a tighter converter and that much spray would be in the 9's pretty easily......
If you can't handle the truth, you're living a lie.......
Re: What should I expect? [Re: Big Squeeze] #758773
07/27/10 08:04 PM
07/27/10 08:04 PM
Charlotte NC
Charlotte NC
Thanks for the replies!!! I didn't want to add alot of varibles to this question but when the engine comes out the heads are off to Ryan @ S-D to do his stage 4 port work and I'm also having him supply a cam. My goals are to go mid to high 10s on muscle (Ryan thinks this very possible) and then hit it with the gas. So that being said my goals are to get into the nines on a fairly simple set up.
Re: What should I expect? [Re: cudadave72] #758774
07/27/10 09:01 PM
07/27/10 09:01 PM
UK
602heavy Offline
602heavy  Offline
UK
My 4300lb 440 combo went from 12.5 to 10.9 on a 250 hit........had my fair share of mishaps along the way..... balloned convertor which took out main bearings/crank , lifted ring lands on pretty much all pistons , blistered molly off the rings on most cylinders , snapped a couple of half shafts , tore the ring & pinion up , blew throttle plates off , set light to wiring along bulkhead , sheared front planetary gears , blew a core plug out..........seem to have a better handle on things these days.
Re: What should I expect? [Re: 602heavy] #758775
07/27/10 09:06 PM
07/27/10 09:06 PM
Charlotte NC
Charlotte NC
Re: What should I expect? [Re: cudadave72] #758776
07/27/10 09:09 PM
07/27/10 09:09 PM
UK
602heavy Offline
602heavy  Offline
UK
A few things to think about when running the bottle , especially with heavy motors a bigger hits.
Re: What should I expect? [Re: 602heavy] #758777
07/27/10 09:15 PM
07/27/10 09:15 PM
Charlotte NC
Charlotte NC
I have ran nitrous on most every (fast) car I have owned but never over a 175 shot. I will be paying close attention to the tune. I'm also going to invest in a good wide band as well. One solenoid glitch can ruin a good day!!
Re: What should I expect? [Re: cudadave72] #758778
07/27/10 09:23 PM
07/27/10 09:23 PM
UK
602heavy Offline
602heavy  Offline
UK
Wide band won't help on a nitrous motor , reading plugs will be you're saving grace.....get a decent ring pack in that motor if you're gonna spray over a 150 shot , would also change that convertor out for anti balloon plated , lots more to add but this post is 'what will i pick up' so don't really wanna step on you're toes.
Re: What should I expect? [Re: 602heavy] #758779
07/27/10 09:27 PM
07/27/10 09:27 PM
Charlotte NC
Charlotte NC
Actually I want all the feed back I can get. I appreciate your input. This would be a big step for me and doing it right is what I'm all about!
Re: What should I expect? Nitrous gurus... [Re: cudadave72] #758780
07/27/10 09:52 PM
07/27/10 09:52 PM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
the main problem will probably be converter. if it's good now on motor it's probably gona be too loose on the bottle. my 471 had 10 to 1 a tight converter and too much cam. Only ran 6.8 to 7.0 at 103 in the 1/8 but with a 200 shot it would wake that converter and cam up to a 5.70 at 123.
Re: What should I expect? Nitrous gurus... [Re: plycuda] #758781
07/27/10 10:39 PM
07/27/10 10:39 PM
Gainesville Fl
mphsmitch Offline
mphsmitch  Offline
Gainesville Fl
I went from 12.50s to 11.30s with a 125 shot with my dakota. I read on the bullet that a guy with a 90 mustang went from 11.30s to 9.70s with a 225 tune up from one of the nitrous gurus.
90 Dakota 408 CID R/T heads 727 trans 9.5 converter 8.8 rear Pro 275/60 drag radials [email]11.09 @120mph[/email] N/A
Re: What should I expect? Nitrous gurus... [Re: mphsmitch] #758782
07/27/10 11:17 PM
07/27/10 11:17 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
A 10 sec E-body with a smallblock, is a healthy ride and as such, will no doubt be convertered and geared correctly for it to run that way. That said, that same combo will not be nitrous friendly, for a larger hit, anyway. The converter will likely be way too loose and the rear gear, likely too steep. You simply can't have it both ways....ie runs balls out on motor and then be able to hose it heavily. You have to pick one or the other. If you build it for spray, it will likely be a turd on motor, because of the required tight converter and less gear. Go the other way and a decent sized hit, will blow right through the converter, plus put the car on the limiter in high gear. All that said, if the car goes low 11s and is properly put together to spray, it will easily run 9s on a 200-250 hit.
Monte
Re: What should I expect? Nitrous gurus... [Re: Monte_Smith] #758783
07/28/10 12:01 AM
07/28/10 12:01 AM
north west, IN
larry890 Offline
larry890  Offline
north west, IN
So if you have a n/a motor that runs good 10ohs. and you want to have a little added insurance of a win. Do you think your better off with a smaller kit 150 or so.
Re: What should I expect? Nitrous gurus... [Re: larry890] #758784
07/28/10 08:52 AM
07/28/10 08:52 AM
Charlotte NC
Charlotte NC
Thats a good question
Re: What should I expect? Nitrous gurus... [Re: cudadave72] #758785
07/28/10 01:15 PM
07/28/10 01:15 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Depends how much your definition of a "little" added insurance is........A real 150 shot is a pretty good hit......
Say you've got a 650HP motor that's running low 10's @ 3,300LBS.......and you add a REAL honest to goodness 150HP, you'd be making 800HP!!!! That should easily push you into the mid 9's...... That's a lot more than a "little" insurance to me......
Re: What should I expect? Nitrous gurus... [Re: Big Squeeze] #758786
07/28/10 03:21 PM
07/28/10 03:21 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I was running a 94 ram 2wd with a 440 mild hyd cam 10-1 comp. a loose 9.5" 4000 G.E.R converter(junk to start with) and 4.10 gear. The truck was running 12.60's with a 1.734 60', put a nos super powershot with 150 jets and it ran a 1.54 60' 11.58 @ 118 mph. Throttle switch only spraying it full pass.
67' charger 499 RB 10.57 at 127
Re: What should I expect? [Re: moparniac] #758787
07/28/10 04:31 PM
07/28/10 04:31 PM
Colorado,U.S.A
4404dart Offline
4404dart  Offline
Colorado,U.S.A
It honestly took a 36 nitrous jet in the fogger (350)for me to go 8.80's @ 158, that was at more or less 8000 ft DA, and a 10.5 on motor. This year it has gone 10 flat on motor, so I'm hoping for 8.60's this weekend, 1/8 mile mph is up from 125 to almost 130, so we'll see? I follow what Monte says, and agree that it is hard to have it both ways. I did not read everything and I'm sure it was mentioned, but be conservative on the timing to start off. I like my air/fuel meter and it gives me a place to start, but nothing can replace looking at the plugs, and getting some expert help on what your looking at. Sounds like you have some experiance already. It was about the time I started spraying 250 and more that the weak links started showing up, such as suspension, too loose a convertor, too much gear, weak fuel system etc. I think it will run a 9!
