Alcohol carb guys #758596
07/26/10 05:07 PM
07/26/10 05:07 PM
ms
W
w2dak394 Offline OP
w2dak394  Offline OP
W
ms
I have a older bg carb that was on my buddy's circle track car for two races then went back to gas. Its an 830 with removable sleaves set up for circle track racing on alcohol. What modifications needed to change it to drag race setup?
Re: Alcohol carb guys [Re: w2dak394] #758597
07/26/10 06:31 PM
07/26/10 06:31 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
shouldn't need much perhaps some rear jet extensions.
Re: Alcohol carb guys [Re: MegaDart] #758598
07/27/10 08:24 AM
07/27/10 08:24 AM
ms
W
w2dak394 Offline OP
w2dak394  Offline OP
W
ms
Any others?
Re: Alcohol carb guys [Re: w2dak394] #758599
07/27/10 10:56 PM
07/27/10 10:56 PM
Southern IL.
jafr Offline
jafr  Offline
Southern IL.
not 100% sure but I believe that those carbs have both front and rear power valves. I would remove the rear power valve. The other thing to look at is this carb or most circle track carbs usualy only have 30cc accelerator pumps, if you are foot braking this carb you would probably want to switch to 50cc pumps front and rear. and as stated in the previous post add jet extensions to the rear.
Re: Alcohol carb guys [Re: jafr] #758600
07/27/10 11:15 PM
07/27/10 11:15 PM
ms
W
w2dak394 Offline OP
w2dak394  Offline OP
W
ms
