Re: PCV and Hemi Stage V intake
[Re: mickm]
#758554
07/26/10 11:22 PM
07/26/10 11:22 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
you know, i never thought of that.
i run mine to the rear carb only as well, but that means a completely different air/fuel mixture going into the rear carb than the front.
but where does the stock one go, into the manifold? i know for sure it doesn't go to both carbs, so if it does not go to the manifold, then it goes to the rear carb.
I think on the stock one it just goes to rear carb, but the intake is also a dual plane. See when I have nothing to do I think of these things
[Re: VanishPt]
#758560
08/02/10 09:17 PM
08/02/10 09:17 PM
Posts: 4,179 California
mickm
California
last one
that is a nice setup. have you played around with it in any way to see what difference it makes, from reading the plugs or anything else?
[Re: VanishPt]
#758562
08/02/10 09:37 PM
08/02/10 09:37 PM
mickm
California
no, i have not> It would just seem to me that connecting both carbs would be create a more even distribution than hooking up just one.
yup, makes sense. thanks.
